I have a differential IF (intermediate frequency) signal generated by an ADL5801 RF mixer.
Stage 1: the signal is amplified before active filtering and it has LC LPF in the beginning for filtering unwanted frequencies above 2 MHz.
Stage 2: the signal is passed through a Sallen-Key HPF with -40 dB/dec, Fc= 400 KHz.
Stage 3: the signal needs more amplification because of filtering in stage 2. The gain is not fixed. It will be controlled by an MCU with a digital potentiometer. Stage 3 is suggested in this section as an answer to my other question which simplified the circuit.
ADC range is 0 - 3.3 V and max sampling frequency is 5.6 MHz or 3.3 MHz will be used. Signal frequency range of interest is 1 kHz to 1.5 MHz or so. 1.65 V is generated by an LDO which is stable with 10 μF output capacitance.
My questions are:
Do I need biasing at stage 3 (ADA4807 part of the first schematic)? Is stage 3's design correct in general?
Both the LT6232 and the ADA4807 have a low differential input resistance (7.5 kΩ and 35 kΩ). What resistor values should I select for gain, or do I need another op-amp?
