I was pestering this community with questions for a while now. The answers I've received were put into the circuit below. I've decided to post it here in case someone else is looking for this kind of device (I've seen at least 3 related questions) and also as a sanity check for myself.
Here are the requirements:
- max 2mA idle, operational down to 18.9V
- standoff 29.8V, activate at 30.8V
- dissipate 450W at least for 2 seconds.
The formal questions would be: Are there any glaring errors in the schematic above? Is there something I can do to improve it before sending to manufacturing?
My big thanks to everybody for their answers and patience.
UPDATE:
I also would like to mention that this circuit is a functional analog to one of the commercial devices we were successfully using before (and I believe to any basic shunt regulator as well). The differences are as follows:
- They are using logic gate with schmitt trigger input as a comparator with hysteresis. I am using actual comparator chip for more precise and easily adjustable thresholds and hysteresis. I don't think this would make the circuit worse.
- They are using zener + NPN regulator for everything: logic, reference and gate drive. I have split supply to have more stable reference and also higher voltage/current gate drive capability. I don't think this would make the circuit worse either.
- They are driving the gate from the logic output via 100R resistor. I am using gate driver with split outputs to provide more "punch", especially for switching off the FET. The idea was to have an option to use IGBT and also reduce switching losses in MOSFET. This is one point that I am not sure about, because faster switching means the auto-oscillation frequency will also raise. Having said that, I can always increase gate resistor to get same slope as in commercial product.
