I have a Mean Well SMPS (RS-15-12) with an isolated DC output. From my understanding, a floating ground is basically a 0V reference without any connection to mains earth (hence floating).
However, what if I have a protection diode that shorts the output to ground in case of polarity reversal (see attachment)? Would this still be safe, or should I connect the V- terminal on the SMPS to mains earth? (Note: V- on the schematic refers to a negative voltage, NOT the V- terminal of the SMPS).
These diodes are placed on the end (output) of a split supply, and are intended to redirect current to circuit ground (SMPS V- terminal) in case of polarity reversal during shutoff or component failure.
Help would be appreciated.
Can you elaborate? It's unlikely for a PSU to generate voltage with reverse polarity. So maybe you mean something specific? \$\endgroup\$
