I tend to struggle computing the Thévenin voltage. Here is a simple example in which I reason wrongly. After open-circuiting, we reach the following:
Here I would argue as follows:
- As \$V_{\text{Th}}\$ is the voltage difference from \$B\$ to \$A\$, I place \$V_{\text{Th}}\$ next to \$A\$ and ground next to \$B\$:
- Now the voltage across \$2R\$ is \$V_{\text{Th}}-V_1\$, giving \$V_{\text{Th}} = V_1 + 2IR\$.
The solution, consisting of the following:
does point to my reasoning being wrong.
What is wrong with my reasoning? How is the reasoning of the solution explained?
A=Matrix([[1,-1,0],[-1,0,1]])
andC=Matrix([[1/(2*r),0],[0,1/r]])
andW=A.T*C*A
andP=W.extract([0],[0])
andQ=W.extract([1,2],[0])
andR=W.extract([1,2],[1,2])
and then find that-P.inv()*Q.T*Matrix([v1,0])
givesMatrix([[v1/3]])
? (Currents in and out of the voltage nodes would be from the Schur complement:(R-Q*P.inv()*Q.T)*Matrix([v1,0])
equalsMatrix([[ v1/(3*r)],[-v1/(3*r)]])
.) \$\endgroup\$
