Through research I am aware that using the CC lines one can advertise "Default" (500mA for 2.0 and 900mA For 3.0+), 1.5A and 3A before getting into PD territory, but none of these include provisions for backwards compatibility with the standards of a bus powered USB 2.0 Hub which is limited to 500mA total, meaning a realistic limit of typically 100mA per port for a 4 port hub (where 100mA is reserved for the controller itself).
What is the correct procedure downstream facing USB 2.0 Type-C ports in this situation however, where there indeed is a hard limit to the power available to the hub that is in alignment with USB 2.0 standards?
To restate differently; how can one avoid advertising currents that a bus powered USB 2.0 hub controller (limited to 500mA total and 100mA per port), cannot support such as the all of the current ratings that CC lines can advertise using Type-C Downward Facing Ports?
I found a relevant excerpt from the USB Specification that I believe answers my question, though the phrasing is not crystal clear to me so I could definitely use reassurance.
When a Source is advertising USB Type-C Default current, the Sink behavior is defined as follows:
- It connects as a USB 2.0 or USB 3.2 device, after which the Sink shall follow the appropriate USB specification.
- It enters a USB PD contract, after which the Sink shall follow the USB PD specification to determine the current (e.g., Rp will no longer be Default as it is superseded by the USB PD contract).
- It detects a USB BC 1.2 charging port, after which the Sink shall follow the USB BC 1.2 specification.
- It attaches as a USB Type-C Power Sinking Device (PSD), after which the Sink may draw up to 500 mA.
This to me indicates that if set to the "Default" advertisement, the connecting device should refer to the standard means of evaluating available current which for this use case would be first with the minimum pre-enumeration current of 100mA, followed by the post-enumeration current of 100mA (As this is for a USB 2.0 hub controller in "bus powered" mode).
The specific document referenced was "Universal Serial Bus Type-C Cable and Connector Specification Release 2.0 August 2019"
