6
I've been creating an I2C library for communicating with ITG3200 gyroscope for MSP430g2553 experimental launchpad. I still have slight problems with sequential reading and the signed values but I'm nearly complete. Can you help out the last problems that I'm dealing with? It seems that I'm stuck on a point. Here is the library http://e2e.ti.com/cfs-file.ashx/__key/communityserver-discussions-components-files/166/8272.i2c_5F00_lib.rar
family user guide : http://www.ti.com/lit/ug/slau144i/slau144i.pdf
gyro user guide : https://www.sparkfun.com/datasheets/Sensors/Gyro/PS-ITG-3200-00-01.4.pdf
If you do not want to download those 3 source files, here is the explanation of the required functions:
Main:
WDTCTL = WDTPW + WDTHOLD; // Stop WDT
BCSCTL1 = CALBC1_1MHZ; // Set DCO to 1Mhz
DCOCTL = CALDCO_1MHZ;
P1SEL |= BIT1 + BIT2 + BIT6 + BIT7; // Assign I2C pins to USCI_B0 // Assign Uart pins to USCI_A0
P1SEL2 |= BIT1 + BIT2 + BIT6 + BIT7; // Assign I2C pins to USCI_B0 // Assign Uart pins to USCI_A0
init_I2C(); // initialize i2c
initUart(); // initialize uart
I2C init:
void init_I2C(void) {
    UCB0CTL1 |= UCSWRST; // Enable SW reset
    UCB0CTL0 = UCMST + UCMODE_3 + UCSYNC; // I2C Master, synchronous mode
    UCB0CTL1 = UCSSEL_2 + UCSWRST; // Use SMCLK, keep SW reset
    UCB0BR0 = 10; // fSCL = 1Mhz/10 = ~100kHz
    UCB0BR1 = 0;
    UCB0I2CSA = itgAddress; // Slave Address is 069h
    UCB0CTL1 &= ~UCSWRST; // **Initialize USCI state machine**
    IE2 |= UCB0RXIE + UCB0TXIE; // Enable RX and TX interrupt
Receive function:
uint8_t Receive(char registerAddr){
    uint8_t receivedByte;
    while (UCB0CTL1 & UCTXSTP); // Ensure stop condition got sent
    UCB0CTL1 |= UCTR + UCTXSTT; // I2C start condition with UCTR flag for transmit
    while((IFG2 & UCB0TXIFG) == 0); //UCB0TXIFG is set immidiately
    UCB0TXBUF = registerAddr; //write registerAddr in TX buffer
    while((IFG2 & UCB0TXIFG) == 0); // wait until TX buffer is empty and transmitted
    UCB0CTL1 &= ~UCTR ; // Clear I2C TX flag for receive
    UCB0CTL1 |= UCTXSTT + UCTXNACK; // I2C start condition with NACK for single byte reading
    while (UCB0CTL1 & UCTXSTT); // Start condition sent? RXBuffer full?
    receivedByte = UCB0RXBUF;
    UCB0CTL1 |= UCTXSTP; // I2C stop condition
    return receivedByte;
Uart init:
void initUart(void) {
    UCA0CTL1 |= UCSSEL_2; // Use SMCLK
    UCA0BR0 = 104; // 1MHz 9600
    UCA0BR1 = 0; // 1MHz 9600
    UCA0MCTL = UCBRS0; // Modulation UCBRSx = 1
    UCA0CTL1 &= ~UCSWRST; // **Initialize USCI state machine**
integer print:
void serialPrintInteger(uint16_t num) {
    int i;
    uint16_t num_send[5];
    uint16_t numTemp;
    num_send[0] = num/10000; // extract 5th digit
    numTemp = num % 10000; // get remaining 4
    num_send[1] = numTemp/1000; // extract 4th digit
    numTemp = numTemp % 1000; // get remamining 3
    num_send[2] = numTemp/100; // extract 3th digit
    numTemp = numTemp % 100; // get remaining 2
    num_send[3] = numTemp/10; // extract 2th digit
    num_send[4] = numTemp % 10; // extract 1th digit
    if(num_send[0] > 0) { // if num is 5 digit
        for(i = 0 ; i <= 4 ; i++)
            serialWrite(num_send[i]); // send each digit as one byte
    else if(num_send[1] > 0) { // if num is 4 digit
        for(i = 1 ; i <= 4 ; i++)
    else if(num_send[2] > 0) { // if num is 3 digit
        for(i = 2 ; i <= 4 ; i++)
    else if(num_send[3] > 0) { // if num is 2 digit
        for(i = 3 ; i <= 4 ; i++)
    else { // if num is 1 digit
        serialWrite(num_send[4]);
void serialPrintAscii(uint8_t ascii) {
    UCA0TXBUF = ascii;
    while (!(IFG2&UCA0TXIFG)); // USCI_A0 TX buffer ready?
And here is my problem. When i try these readings in my main loop seperately i get the results that i should have.
serialPrintInteger(Receive(0x00));
or
serialPrintInteger(Receive(0x15));
or
serialPrintInteger(Receive(0x16));
and the outputs of these are 0x69 from Receive(0x00) which reads slave address register of the gyroscope, 9 from Receive(0x15) where i wrote 9 inside 0x15 register for configuration and 25 from Receive(0x16) where i wrote aswell.
I don't think my serialPrint functions are corrupted aswell, I've tried with a lot of combination under range of 16 bit where it should be. This sequence is working fine:
serialPrintInteger(5);
serialPrintAscii(Ascii_Comma);
serialPrintInteger(10);
serialPrintAscii(Ascii_And);
serialPrintInteger(15);
serialPrintAscii(Ascii_Dot);
I see an output like this in my serial console: 5,10&15.5,10&15.5...
The funny part starting when i try this logic on my Receive function. Here is the sequence i use
serialPrintInteger(Receive(0x00)); // result 105
serialPrintInteger(Receive(0x15)); // result 9
The sequence in my console is like this: 105,105&9.105,105&9.105...
First i thought i wasn't properly send NACK to the slave for single byte and i thought it kept incrementing the register address on his own but they are working fine seperately and gyro has x,y,z registers aswell and they are not corrupting my sequence.
I was struggling with gyro motion registers for a while but i realised that I'm not in full control of my I2C just yet. So can you point out what i'm doing wrong here?
  • \$\begingroup\$ Consider making your code more readable en.wikipedia.org/wiki/Indent_style \$\endgroup\$
    – jippie
    May 19, 2013 at 14:45
  • \$\begingroup\$ Not sure I understand your problem, don't you miss CR (carriage return, 0x0d) and LF (line feed, 0x0a) in your serialPrint? \$\endgroup\$
    – jippie
    May 19, 2013 at 15:05
  • \$\begingroup\$ Or is it the fact that your serial receive buffer isn't flushed after reading it, probably reading over a NULL (0x00) terminator byte? \$\endgroup\$
    – jippie
    May 19, 2013 at 15:07
  • \$\begingroup\$ Actually, my code has the indentation. It is my mistake that after pasting here, i did not correct it, i will do that now. For your second question, my serial reader drive checks the '.' byte as an ascii for a termination, so i'm basicly keep filling the buffer with '.' Thirdly, according to the user guide of the device, USCI_A Uart module flush the TX buffer after the byte sent completely, actually it's a shift register so flushing should not be the problem. \$\endgroup\$ May 20, 2013 at 8:07
  • \$\begingroup\$ For the love of Pete, why aren't you using printf in stdio.h instead of writing your own version. That will help your troubleshooting greatly. Write less code! \$\endgroup\$ Dec 19, 2014 at 20:51
This question has been solved in Ti website and the following is the solution which he added:
From looking at the USCI Operation, I2C mode section in the MSP430x2xx >Family User's Guide SLAU144I I think the UCTXSTT bit will be cleared after >the slave has ACKed its receive address, and before the data has been read >from the slave. Therefore, the following in the Receive function could read >the UCB0RXBUF before the data has been received:
Try changing to:
 while((IFG2 & UCB0RXIFG) == 0); // Wait until data read
Chester Gillon's post
I fixed my problem by changing some parts in the Receive function. Thanks >to Chester Gillon's post, it made me realise that STT interrupt occurs >right after the slave ACK the master. After checking the user guide >carefully, i found this:
If a master wants to receive a single byte only, the UCTXSTP bit must be >set while the byte is being received. For this case, the UCTXSTT may be polled to determine when it is >cleared:
So this STOP condition must occur after the ACK but before the second data >ACK. So i changed my receive function into this and it solved all my >problems:
uint8_t receivedByte = 0;
UCB0CTL1 |= UCTR + UCTXSTT; // I2C start condition with UCTR flag for >     transmit
while((IFG2 & UCB0TXIFG) == 0); // wait until TX buffer is empty and >     transmitted
UCB0CTL1 |= UCTXSTT; // I2C start condition with NACK for single byte >     reading
while((IFG2 & UCB0RXIFG) == 0); // wait until TX buffer is empty and >     transmitted
receivedByte = UCB0RXBUF; // I2C stop condition
Barışcan Kayaoğlu's post
https://e2e.ti.com/support/microcontrollers/msp430/f/166/t/265825
  • \$\begingroup\$ Unfortunately, link-only answers are not useful on SE sites. If the linked site goes down or removes content, then a link-only answer is useless to any future searchers. Please summarize the solution given at the link. Also, you may notice that the OP posted the same question there as here... \$\endgroup\$ Jul 19, 2016 at 11:27
  • \$\begingroup\$ I will modify it, but he didn't put the solution here. \$\endgroup\$
    – I.Omar
    Jul 19, 2016 at 13:17
