I'm trying to make a circuit that can output an 80 Hz PWM signal. I'm planning to use an Arduino to switch an optocoupler that will control the duty cycle.
Here is my circuit:
After building the circuit, I used a multimeter to measure the output voltage and frequency. The voltage was 11.5 V and the frequency was 0 Hz.
I also changed R1 and R2 to 1 Mohm resistors. The output voltage was 3.64 V and output frequency was 79.41 Hz.
My questions are:
  1. Why is the multimeter showing a different result with different resistance? In my understanding, it should provide a constant voltage and frequency with different resistance.
  2. Is MOC3032M suitable to control a DC PWM signal? If not, is there any optocoupler suitable for the task? After doing some research, I realize the zero crossing detection in my optocoupler could interfere with DC signal every time it got turned on and off, but I couldn't find a detailed explanation of this topic.
Here is my Arduino code if it helps.
    int relayPin = 8; // Assign the relay to digital pin 8
    void setup() {
      pinMode(relayPin, OUTPUT); // Set the relay pin as an output
    void loop() {
      digitalWrite(relayPin, HIGH); // Turn the relay on
      delayMicroseconds(3750); // On time: 30% of 12.5 ms (80 Hz cycle)
      digitalWrite(relayPin, LOW); // Turn the relay off
      delayMicroseconds(8750); // Off time: 70% of 12.5 ms
Here is the MOC3032M datasheet.
    \$\begingroup\$ Triac is not used as DC switch. Use optotransistor. \$\endgroup\$
    – user263983
    Jan 18 at 2:04
The MOC3023M is most unsuitable for your project. It has a TRIAC output stage which is designed for AC supplies and, to complicate further, it has zero-cross switching. I have written a little about these on Opto-triacs and zero-cross detection.
Figure 1. Internals of a zero-cross detection circuit based on the similar G3MB-202P with 5 V input.
TRIACs have the characteristic that, once switched on, they stay on until the current through the TRIAC falls below the hold-on value. (That means something external to the TRIAC is required to turn it off. Usually that's the zero-crossing of the mains voltage.)
For your application you need an opto-isolator with a transistor output.
