I have an already-designed board that uses an ATmega32U4 (a board of our own design). It is USB-powered at 5V and it has an external 16MHz crystal.
Below is a screencapture of the relevant portion of the schematic:
The firmware is built as an Arduino project (a single .ino file), based on the Pro Micro.
I have several reasons to move the design to 3.3V (still USB-powered, so I can simply add an LDO to generate the 3.3V); thus, the external crystal will have to be 8MHz. However, my doubt/question is about the 48MHz internally-generated USB clock signal: I don't see anywhere in the .ino file anything related to setting up the MCU's PLL; would that be part of the bootloader? Would I need to adjust the bootloader? Obtain and flash a bootloader image specifically for 8MHz clock?
I think the bootloader uses this module to initialize the USB hardware: USBCore.cpp
This is the relevant code fragment:
// ATmega32U4
#if defined(PINDIV)
#if F_CPU == 16000000UL
    PLLCSR |= (1<<PINDIV);                   // Need 16 MHz xtal
#elif F_CPU == 8000000UL
    PLLCSR &= ~(1<<PINDIV);                  // Need  8 MHz xtal
#else
#error "Clock rate of F_CPU not supported"
#endif
I think you must recompile the bootloader with the option
F_CPU = 8000000
in the caterina Makefile or try to use the caterina-LilyPadUSB bootloader. That seems to be compatible to your design and expects an 8 MHz crystal.
  • \$\begingroup\$ Sorry it took me a while to mark it as answered; I was tempted to do so as soon as I was convinced that this was the correct answer, but then I figured I'd wait to receive and try the boards — that took longer than anticipated, but finally yesterday we received them, and indeed things worked following your suggestion! \$\endgroup\$
    – Cal-linux
    Mar 9 at 18:33
  • \$\begingroup\$ BTW, we just downloaded the binary (caterina-LilyPadUSB.hex) and flashed it, and then we could flash the Arduino code via the USB. \$\endgroup\$
    – Cal-linux
    Mar 9 at 18:34
