I'm not much of an engineer, but I have worked with arduino. I'm looking to see if it's possible to build a pulse proportional thermostat with a probe and an arduino. Any recommendations on where to begin would be appreciated. Note: I couldn't find an arduino shield for something like this, so I thought asking here would be a good start.
  • \$\begingroup\$ Would that be an analog to PWM converter? Use analogWrite(); to one of the PWM pins on Arduino. \$\endgroup\$
    – jippie
    Commented May 20, 2013 at 8:14
  • \$\begingroup\$ Could you describe what you expect the pulse to look like? Does it get wider with temperature? How often is the pulse expected to be produced? Once per second? Hundreds of times per second or more? What voltage level does the pulse need to be? Does it need to be voltage or should it be current? \$\endgroup\$
    Commented May 20, 2013 at 11:43
  • \$\begingroup\$ Sounds like a PID with a PWM output where the PWM window is a couple of minutes? But I am only guessing, since there is not much info here... \$\endgroup\$
    – Johan
    Commented May 21, 2013 at 4:38
