How can I measure the internal resistance of a thermoelectric generator? Can I use a standard multimeter? I am using a TEC1-12706B thermoelectric generator. I tried to use a standard multimeter to measure the internal resistance. Later I found that it is a positive component so that my measurement is wrong.
  • \$\begingroup\$ What value did you get for the internal resistance? How did you try to measure it? \$\endgroup\$
    – JRE
    Jan 24 at 7:49
  • \$\begingroup\$ I connected a resistor to the thermoelectric generator and then measure the current through it, after that I used the formular R= U/I to calculated the internal resistor and found r= 517.8 Ohm \$\endgroup\$ Jan 24 at 8:18
I connected a resistor to the thermoelectric generator and then measure the current through it, after that I used the formular R= U/I to calculated the internal resistor and found r= 517.8 ohm.
Figure 1. Source resistance measuring circuit.
  • Stabilise the TEG temperature.
  • Measure the open-circuit voltage output, \$ V_{OC} \$.
  • Connect the load and measure the voltage under load, \$ V_L \$.
  • Calculate the current, \$ I = \frac {V_L} {R_L} \$.
  • Calculate the voltage drop across \$R_S\$, \$ V_d = V_{OC} - V_L \$.
  • You now have the voltage drop across \$ R_S \$ and the current through it so you can calculate, \$ R_S = \frac {V_d} I \$.
