I am trying to build a biasing sequence circuit for a GaN power amplifier.
The GaN power amplifier I am using has a particular bias-up and bias-down sequence as shown below:
The figure below is a part of a GaN power amplifier sequencing circuit:
Here I am trying to switch the drain of the power amplifier. The PULSE_IN signal goes to the drain of the power amplifier. Initially the POT(VR1) is set such that VG1_REF is 5 V .
DURING TURN-ON:
The VG1_REF signal (5 V) goes to an inverting amplifier and the output of that inverting amplifier (-5 V) is given to the gate terminal of the PA which sets the Gate of the PA in pinch-off first. For that to happen R17 is grounded using Q4 (Initially the ENABLE_1 signal is given which would be a constant high. That will turn-on the Q4 and R17 will be grounded).
Next, I will give the PULSE_IN signal to the drain of the power amplifier.
Next, I will send a constant low signal from ENABLE_1 so that Q4 will be turned-OFF and I will adjust the POT (VR1) to set the VG1_REF (Gate voltage to approx. ~ -2.2 V) to get my required drain current
And finally I will give my RF input signal.
DURING TURN OFF:
First I will remove my RF input signal
Next, I will reset the POT (VR1) such that VG1_REF will be 5 V and send constant high from ENABLE_1 to turn ON Q4 so that a pinch off voltage (-5 V) is applied to the Gate terminal of the PA.
Then I will turn-off the PULSE_IN signal (to turn-off Vd).
Then I will finally turn-Off ENABLE_1.
I want to control the constant voltages from ENABLE_1 and the pulsed signals from PULSE_IN using a single Control circuitry. So, please suggest how can I control ENABLE_1 and PULSE_IN together according to the logic I explained above.
To sum-up the required logic:
During TURN-ON
- ENABLE_1 -> Constant high
- PULSE_IN -> Pulse input
- ENABLE_IN -> low to adjust the POT (while PULSE_IN not turned-off)
- RFIN -> given to PA
DURING TURN-OFF:
RFIN -> TURN OFF
ENABLE_1 -> CONSTANT-HIGH
PULSE_IN -> OFF
ENABLE_1 -> OFF
Thanks in advance.
