What are the possible sample rates for both transmit and receive on the Ettus USRP B200 mini ? This SDR uses the AD9364 chip.
Does the radio use integer divisors of the master clock rate? Or does it support arbirtrary sample rates as suggested here?
Too many to explicitly list. Whatever clock rate the synthesizer on the ad936x can generate, divided by an integer between 1 and 512.
Yes
That page does not suggest that.
  • \$\begingroup\$ where did you see the integer decimation between 1 and 512? \$\endgroup\$ Commented Jan 26 at 1:25
  • \$\begingroup\$ Memory of the verilog source code of the ddc and Duc chains.. These are Foss. \$\endgroup\$ Commented Jan 26 at 2:13
  • \$\begingroup\$ How would a normal person find those? \$\endgroup\$ Commented Jan 26 at 2:27
  • \$\begingroup\$ Try and set a sample rate below the minimum of I think 192 kHz and UHD will just tell you there is a limit \$\endgroup\$ Commented Jan 26 at 9:21
  • \$\begingroup\$ Is this documented somewhere? \$\endgroup\$ Commented Jan 26 at 13:52
