I'm stuck with this doping problem and can't figure out where to go with it.
The built-in voltage of a GaAs pn junction diode is 1.25 V when the diode's temperature is T = 320K. The cathode region of the diode is doped with phosphorus at a concentration of 1e17 \$cm^{-3}\$. Determine the required doping concentration in the anode region.
Would I go about this by using the equation \$V_{bi} = V_T\cdot ln(N_a\cdot\frac{N_d}{n_i^2})\$?
\$V_T\$ being the thermal voltage
\$N_a\$ being the acceptor concentration on p side
\$N_d\$ being the donor concentration on the n side
\$n_i\$ being the intrinsic carrier concentration
I have completed the following work for the above question. Can I be checked for accuracy please!
