27
I'm considering building an amplifier following instructions from a MAKE magazine article.
However, as I was reading the circuit schematic, I noticed that the author denotes that the capacitors C101, C104, and C105 are supposed to be "film capacitors." Is there a reason as to why one would use film instead of ceramic capacitors in this application? Also, if a website denotes "metal film capacitors", is that the same as a "film capacitor"?
Right now, the only difference I know of in types of capacitors is that electrolytic capacitors have a polarity, while ceramic ones don't. I was wondering if film vs. ceramic has a similar differentiation.
21
"Film Capacitor" typically denotes polyester or polymer film as the dielectric - as another answer points out, metallized film capacitors are the same thing: A metallic coating being applied to an extremely thin polymer film, to create the conducting electrodes of the capacitor.
In general, ceramic capacitors are somewhat non-linear in their frequency and voltage responses, compared to film capacitors. Another issue with ceramic capacitors is that they tend to behave as microphones, thus picking up ambient sound and modulating the voltage across them accordingly.
Also, for smaller values (a few pF), ceramics were more commonly used, while larger values were somewhat likely to have film considered as an option - or at least that was how it used to be, before capacitors became so inexpensive with the advent of SMT, that the price difference became negligible except for huge volumes.
Both film caps and ceramic ones are non-polarized, so that isn't a difference.
    \$\begingroup\$ This would also be a wonderful place to also mention dielectric absorption .. \$\endgroup\$ May 20, 2013 at 18:05
    \$\begingroup\$ @rawbrawb Please do edit in your thoughts. I'll look at the grammar before accepting the edit of course ;-) \$\endgroup\$ May 20, 2013 at 18:06
20
Depending on the exact type, ceramic capacitors tend to have some nonlinearities. What makes them less than ideal in the audio signal path is, most of all, the varying capacitance with a change in voltage. Here's a diagram for various types of ceramics (and it doesn't even show ceramic dielectrics like Y5V):
Voltage Dependance of Capacity for Ceramic Capacitors Image Source: Wikipedia
With your audio signal changing, your capacitors change, too. This causes non-harmonic distortion.
Think of a high-pitch note superimposed on a bass note. While your bass note is close to zero, your higher note passes through a capacitor with the nominal value. When the momentary voltage of your bass note is higher, a (bad) ceramic capacitor has a lower value, i.e. your high pass filter has a higher cutoff frequency. This may lead to the higher note becoming damped more strongly.
For audio applications, you will often need large capacitor values. Only non-linear types of ceramics tend to have these.
Film capacitors are quite linear and usually better suited for analog signal processing.
    \$\begingroup\$ If one imagines a capacitor as being a vessel of water with a pipe connected to the bottom, adding water will increase pressure. If the vessel is a vertical-axis cylinder, the amount of water required to yield 1psi pressure increase will be constant. If its cross section higher up is smaller, the amount required for each PSI will increase as the water level reaches those areas. The X7R behaves like a flask whose diameter at the top is less than half its diameter at the bottom. \$\endgroup\$
    – supercat
    May 20, 2013 at 18:30
    \$\begingroup\$ I am not sure if I understand your comparison... If we are talking about hydrostatic physics, the water pressure at the bottom of any vessel is only dependent of the water height, not the shape of the vessel. \$\endgroup\$
    – mFeinstein
    Feb 16, 2016 at 14:47
9
There is another reason for avoiding ceramic capacitors:
Piezoelectric effects.
Some ceramic caps (particularly MLCC SMT parts) can actually generate voltage across their terminals when subjected to physical stress.
Ceramic caps are also often microphonic, which predictably can cause issues in analog applications.
The ceramic EIA Class 2 dielectrics used in high-K capacitors ("Z5U" and "X7R") are piezoelectric and directly transform mechanical vibration into a voltage in exactly the same way as a ceramic or piezoelectric microphone.[2] Film capacitors using soft (mechanically compliant) dielectric materials can also be microphonic due to vibrational energy physically moving the plates of the capacitor. Likewise, variable capacitors using air as a dielectric are vulnerable to vibrations moving the plates. Capacitors using glass as the dielectric, while quite expensive, can be made to be essentially nonmicrophonic.
