Most datasheets I read through have a thermal resistance rating attached to the particular package the semiconductor comes in (i.e. TO-220, D2PAK, TO-3P, etc), usually in the form of θJA (junction-to-ambient) °C/W.
Some questions:
What is the difference between θJA and θJC, and which should be used to calculate temperature rise above ambient (assume 25°C room temperature) with the formula P = I·V, where V is voltage dissipated (i.e. linear regulator dropoff), I is current, and P is power in watts?
How do you calculate the needed heatsink rating in °C/W using the prementioned ratings (without use of a fan for forced airflow, static heatsink only)?
