I picked up a dog collar at a yard sale that didn't come with a charger. Looks to use a 3pin charge port which takes 12v. Don't really want to buy a special charger for just 12v so was wondering how to determine what the pinout might be to make one for myself. I would just open the unit to look at the board, but don't want to break the waterproof seal for the device unless necessary. Thanks!
Picture of port
Link to ebay listing for charger
  • \$\begingroup\$ why would a dog collar require a charger? \$\endgroup\$
    – jsotola
    Commented Feb 2 at 19:05
    \$\begingroup\$ Determining pinout is one thing. Determining if the charger is really a charger or just a power supply is another thing, which likely can't be determined without opening the device. \$\endgroup\$
    – Justme
    Commented Feb 2 at 19:06
  • \$\begingroup\$ @jsotola: it's for a shock collar, illegal in Europe and some other jurisdictions because using one is considered to be animal cruelty there. \$\endgroup\$
    – ocrdu
    Commented Feb 2 at 19:22
  • \$\begingroup\$ If it's an ultrasonic collar for insect/parasite infections, it'll work just as well whether it's charged or not. \$\endgroup\$ Commented Feb 2 at 20:37
Ended up opening it. Counting pins up from middle to outside (1,2,3):
1 = G 2 = +12v 3 = NC
Works just fine with straight 12v. Nothing fancy.
