I need a solution to charge two 3.7 V lithium-ion cells that are in series. However I have a very limited access to modules and I need to have current limitation as my source won't stand beyond 0.5 A.
I have this module available (TP4056 based), but it's for a single cell. Is there any way to make two of these modules do the job?
Datasheet: TP4056
    \$\begingroup\$ We will probably need more than a picture of a PCB to tell. Please link the datasheet to the BMS. \$\endgroup\$
    – Lundin
    Commented Feb 9 at 7:22
    \$\begingroup\$ Almost certainly not. There don't appear to be any transformer-type isolation components on there. Unless you power each from a separate 5 V wall-wart. \$\endgroup\$
    – Neil_UK
    Commented Feb 9 at 8:05
    \$\begingroup\$ You can IF the input to each charger board is isolated (floating). Each battery will then be dealt with separately. || A usually less desirable way is to transfer the charger between batteries as needed - eg using a DPDT relay. \$\endgroup\$
    – Russell McMahon
    Commented Feb 27 at 0:50
No.
If you try, KABOOM!
That's because they are not isolated. Upon connection, they make a short circuit across one Li-ion cell.
Yes, but it's more expensive than buying the correct charger. It involves adding an isolated DC-DC converter between the USB port and one of the charger modules.
    \$\begingroup\$ Or simply using two isolated chargers. \$\endgroup\$
    – Justme
    Commented Feb 9 at 15:18
