When I connect to a PB-02 via UART(8data bits, no parity, 1 stop bit) it does not execute all AT commands. These work fine:
  1. AT\r\n results in AT\r\n\nOK\r\n
  2. AT+RST\r\n results in :
    AT+RST
    \r\n\n
    OK\r\n
    all driver init\n
    ###################\r\n
    \r\n
    arch:phy6212\n
    company:Ai-Thinker|B&T\n
    MAC:94 C9 60 88 DC DB\n
    sdk_version:release/V2.1.0\n
    firmware_version:release/V1008 \r\n
    compile_time:Sep  3 2021 15:41:57\n\r\n
    ready\n
    ###################\n
  3. ATE0 and ATE1 work as expected...
  4. It also dumps messages like CON OK\r\n and DISCONNECT OK\r\n, when I connect with a Test App...
but:
  1. AT+NAME?\r\n and AT+NAME=WhiteTulip\r\n do not work. There is just the echo. But no OK and no name change.
Why is that?
How can I change its name and add parity bits, without flashing new firmware?
  • \$\begingroup\$ To help get an answer, can you edit the question and include a link to the documentation for the PB-02. I'm guessing it is some sort of modem. \$\endgroup\$ Feb 11 at 14:16
  • \$\begingroup\$ They call it "bluetooth module". On the UART side it speaks "AT". And on the airside it speaks Bluetooth BLE 5.0. But: The PDF "PB-01/02 Tmall Genie docking at instruction set" and the PDF "PB-01/02 Bluetooth passthrough (non mesh) at instruction set" describes AT commands, that the PB-02 does not understand. \$\endgroup\$
    – RRIDDICC
    Feb 11 at 14:35
  • \$\begingroup\$ Using google translate to convert the documentation from Chinese (Simplified) to English, I can't see any error in the AT commands you are using for AT+NAME? and AT+NAME=WhiteTulip. The translated document does say Changing the Bluetooth device name requires restarting to take effect. The maximum length is 20 bytes.. Have you tried restarting the PB-02 after attempting to change the name? \$\endgroup\$ Feb 11 at 14:44
  • \$\begingroup\$ @ChesterGillon it does not even reply "OK", although that PDF says, it should do. I just did that AT+NAME=WhiteTulip and then a power cycle, but it still says its name is "ai-Thinker"... \$\endgroup\$
    – RRIDDICC
    Feb 11 at 15:03
  • \$\begingroup\$ Given the firmware doesn't reply to the AT+NAME, you might have to contact Ai-Thinker Technology support to ask why the firmware doesn't even reply "OK". \$\endgroup\$ Feb 11 at 15:14
I found this PDF via Google. It says that it is "BLENAME" in v1.1.3.
AT+BLENAME?<0D>
OK<0D>
AT+BLENAME=White Tulip<0D>
OK<0D>
But: AT+UARTCFG? says just +UARTCFG:115200 (no parity configurable). So I seem to have a special version v1.1.3. So I will use 32bit CRC every few bytes. That should be even better than parity (which is 1bit CRC, IIRC).
