I am trying to create a custom application to control some Bluetooth-controlled LED strips. That is, I would like to reverse engineer how they are controlled without having any datasheet -- I'll figure out the control software itself later. There are a number of tutorials out there, but I have come up against a problem when trying to command them myself.
The LED strips are made by GUPUP (?) and the documentation I've been able to find just describes how to use them with their own app.
I have learned a bit about BLE and GATT and have gotten to the point where I can see a powered-up strip on nRF Connect (on an iPhone) and the services it advertises. There is just the one with an unnamed Notify characteristic and an unnamed Read/Write characteristic:
These are consistent with what I see in LightBlue (another iPhone Bluetooth scanner):
There are plenty of tutorials out there where at this point, I would just write to the writable characteristic and change the color, but I get stuck here. When I try to write to it, not only does the strip not react, the value of the characteristic doesn't even seem to change. The log files from the apps show the write requests, but I can't get the value to be anything other than what you see there: 3031 3233 3435 3637 3800
Meanwhile, I can change the color using either the provided remote (which looks like the same one all Bluetooth LED products come with, but cannot control another Bluetooth LED I have) or the manufacturer's app ("Allbest Home" for iPhone). Those changes do not alter the writable characteristic's value, either, but they do trigger a message sent back on the Notify characteristic when I change something.
So unless I am scanning and/or writing to the characteristic wrong, it seems like these LED strips are controlled in some way that is more complex than just asynchronously writing RGB-encoded bytes. Not sure if it's a coincidence, but the characteristic value that won't change seems to just be the null-terminated string "012345678" in ASCII.
Any clues or leads for me to follow? Is there a time-based protocol (send this, then that, then the next thing, etc.)? Is it actually accepting my writes, processing them, but then overwriting the characteristic with "012345678" immediately after? In that case, I'd need to guess at the proper structure of the characteristic value since I can't get any feedback on successful requests other that a change in the lights themselves.
I have seen third-party apps for controlling similar LED strips, so there must be people out there who have cracked them, but I am out of guesses for what to search for.
I have ordered a Nordic BLE sniffer, but thought I'd post this while I wait in case someone has some insight.
