I want to simulate a 555 circuit in KiCad, but quite failing to do so. I found a SPICE model here and included it in my model like this:
My circuit looks like this:
The transient simulation works. It should oscillate at around 14ms, but it doesn't do so:
How can I simulate the 555 in KiCad?
Update I made the simulation a little longer, and I do get some results, but not quite what I expect:
This is from 3s - 4s: enter image description here
And from 4s - 5s: enter image description here
  • \$\begingroup\$ I think that in Kicad 8, that it's at the moment in 'release candidate 2', there are important improvements in simulation. \$\endgroup\$
    – Gos
    Commented Feb 13 at 11:36
  • \$\begingroup\$ Hmmm...looks like the ngspice engine is having trouble with the transistor-based model. Try adding a SPICE directive to the schematic and see if it helps: .options cshunt=1p \$\endgroup\$
    – Ste Kulov
    Commented Feb 13 at 19:12
  • \$\begingroup\$ Can also try Gear integration method by doing this: .options method=gear \$\endgroup\$
    – Ste Kulov
    Commented Feb 13 at 19:31
Did you give it enough time to start? My model does start after ~2.38sec.
I tested with KiCAD 7.0.8
Simulator, Sim Command, Transient tab, 1m in Time step and Final time set to 3 seconds.
Please see attached picture:
Zoomed in and more signals - the plot looks like this:
NE555 simulation
NE555.lib file downloaded from here: KiCAD forum
---EDIT--- To check if skipping is present.
This is my result when setup is: transient: 100us step, 3 to 4 second simulation. Voltage seems to be a bit unstable, otherwise fine (no skips).
100micro-3secto4sec
Other setup: 10us step, other parameters the same.
10microsec-3secto4sec
And the last one: 1us step.
1microsec-3secto4sec
  • \$\begingroup\$ Thanks, I got it almost... Ran it in KiCAD 7.0.10, see my updated question. Your results are significantly better. \$\endgroup\$ Commented Feb 13 at 10:53
  • \$\begingroup\$ @BartFriederichs Perhaps skip the initial operating point analysis for the transient simulation, by including the "UIC" argument. For example ".tran 1m 1 uic" \$\endgroup\$ Commented Feb 13 at 11:14
  • \$\begingroup\$ @SimonFitch skipping is OK, problem I still have is the results vary even after that initial startup time. \$\endgroup\$ Commented Feb 13 at 11:30
  • \$\begingroup\$ @Bart Friederichs I see your skipping. Also, your voltage levels are somehow uneven. Let me check this on my simulation. I see the .lib files are identical. \$\endgroup\$
    – smajli
    Commented Feb 13 at 22:36
it should oscillate at around 14ms, but it doesn't do so:
It should be 35 ms ... Simulated with microcap v12.
  • \$\begingroup\$ The problem is not with the circuit, but with KiCad. I have successfully simulated it with other tools. I want to use KiCad because my other designs are in there as well. \$\endgroup\$ Commented Feb 12 at 12:09
    \$\begingroup\$ Don't know KiCad. Ok, but the period should be 35 ms, not 14 ms ... \$\endgroup\$
    – Antonio51
    Commented Feb 12 at 12:10
    \$\begingroup\$ @BartFriederichs The problem is with NgSpice that KiCad uses as the SPICE engine. The KiCad project has not developed their own simulator yet :) \$\endgroup\$ Commented Feb 12 at 17:14
