I understand that for single ended RF signals I must ensure that the characteristic impedance of the transmission line matches the load impedance (say 50 ohm). I am a bit confused for differential RF signals though. Do I try and match the differential impedance to 100 ohm and the characteristic impedance to 50 ohm simultaneously?
Clarification would be appreciated
Thanks
Usually this means creating two 50Ω lines that form a differential pair. Because both pairs are also used differential they are coupled to each other so you need to calculate the impedance stackup and width for a 100Ω edge coupled external line. If it's internal on a PCB, you'll need the height between both layers. Use a tool like saturn PCB tool to calculate (diff pairs tab).
