I have a device designed by a more experienced peer of mine. The peer left, and the problem lands on me.
The Mosfet Q1, often got killed (failed to switch on), and the fix was simply replacing it till now.
Recently I smelled the Mosfet overheated and the pcb got toasted in the Drain 1 area. My guess is that the 10k resistor R4 is too high, result Q1 not fully open/close, and the internal resistance got very large, it began to self-charge/discharge...
The ENable is on by default, when off, 18v turns the gates on/off...
So how do I find a right gate resistor? I found this formula: Rgate=Vgate/(Imax) I assume Vgate=18v, but which one is Imax in the datasheet? the Gate resistance in page 2, is that mosfet internal resistance or recommend external Gate resistor I'm looking for?
should there be a discharge resister similar to R3 (for Q3) that discharge any voltage build up by Q1 internal capacitor?
Thank you all, still learning
