PCB vias and components
I know that it's possible for the GND vias to connect to the GND signal layer in a 4 layer stack. How do I achieve this?
    \$\begingroup\$ Polygon properties, pour over all same net objects. \$\endgroup\$ Commented Feb 16 at 9:30
In addition to @9_daytona's answer, you can view a more comprehensive list of polygons in:
Tools -> Polygon Pours -> Polygon Manager.
You can update the net name in this window, as well as creating a New Polygon Pour -> From Board Outline to take the exact shape of your board.
PCB layer in altium designer
  1. Select the layer from the bottom
  2. Properties > Net
