I came across the following circuit on a random website:
phase neutral earth fault detection circuit
Source website
My guess is this circuit is used by some extension boards as shown below:
extension board
I understand that LED1 current (around 2 mA) is flowing into the earth when things are working fine.
My questions are as follows:
  1. Is this an acceptable practice in general?
  2. Will it cause the RCCB/ELCB to trip, assuming someone is using 20-30 such products (extension boards)?
  • \$\begingroup\$ Actually, the current through the LEDs would be about 230/56 = 4.1 mA. \$\endgroup\$ Feb 21 at 12:33
  • \$\begingroup\$ @MathKeepsMeBusy - i am considering half pulse only assuming negative pulse won't pass. that's why I am getting half of what you got. \$\endgroup\$ Feb 21 at 12:40
  • \$\begingroup\$ Yes, I should have taken that into account. Sorry. \$\endgroup\$ Feb 21 at 12:44
If you mean is the circuit suitable then the answer us a big fat "no". LEDs have a maximum reverse voltage that is at best tens of volts and not hundreds of volts.
The design is flawed; it will burn first so I'd be more inclined to worry about that than worrying about tripping an RCCB.
