After get ATR and send PTS, I tried send APDU, but response always the same as APDU which has been sent.
I tried to change the frequency for USART (clock) and baud rate, after I tried to change PTS value for ETU and T=0, but always same result.
Schematic:
Answer from Smart Card:
main code:
int main(void)
    /* USER CODE BEGIN 1 */
    /* USER CODE END 1 */
    /* MCU Configuration--------------------------------------------------------*/
    /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
    HAL_Init();
    /* USER CODE BEGIN Init */
    // uint8_t res2[8] ={0x80,0xCA,0x9F,0x17,0x00};
    /* USER CODE END Init */
    /* Configure the system clock */
    SystemClock_Config();
    /* USER CODE BEGIN SysInit */
    /* USER CODE END SysInit */
    /* Initialize all configured peripherals */
    MX_GPIO_Init();
    MX_USART2_UART_Init();
    MX_USART1_SMARTCARD_Init();
    /* USER CODE BEGIN 2 */
    /* USER CODE END 2 */
    uint8_t response[50];
    /* Infinite loop */
    /* USER CODE BEGIN WHILE */
    HAL_StatusTypeDef convention;
    uint8_t h = 97;
    uint8_t first_request[10] = {0xA0,0xA4 ,0x00 ,0x00,0x02,0x00,0x00,0x00,0x00,0x00};
    uint8_t second[4] = {0x7F,0x00,0x00,0x00};
    uint8_t second2[5] = {0x00,0xB0,0x00,0x00,0x07};
    for(int i=0;i<50;i++)
        response[i] = 0x00;
    uint8_t response2[8] = {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
    uint8_t send[6] = {0xFF, 0x00,0xFF,0x00,0x00,0x00};
    HAL_UART_Receive_IT(&huart2, response,1);
    HAL_GPIO_WritePin(GPIOB, GPIO_PIN_12, 0);
    HAL_GPIO_WritePin(GPIOB, GPIO_PIN_13, 0);
    HAL_Delay(100);
    HAL_GPIO_WritePin(GPIOB, GPIO_PIN_13, 1);
    //  HAL_GPIO_WritePin(GPIOB, GPIO_PIN_14, 1);
    HAL_Delay(15);
    HAL_GPIO_WritePin(GPIOB, GPIO_PIN_12, 1);
    HAL_SMARTCARD_Receive(&hsc1, response, 30, 100);
    HAL_UART_Transmit(&huart2, response, 24, 100);
        response[i] = 0x00;
    HAL_Delay(20);
    HAL_UART_Transmit(&huart2, send, 6, 100);
    HAL_SMARTCARD_Transmit(&hsc1, send, 4,100);
    HAL_UART_Transmit(&huart2, response, 8, 100);
    HAL_UART_Transmit(&huart2, first_request, 8, 100);
        response[i] = 0x00;
    HAL_SMARTCARD_Transmit(&hsc1, first_request, 5,100);
    HAL_UART_Transmit(&huart2, response, 5, 100);
    HAL_SMARTCARD_Transmit(&hsc1, second, 2,100);
    HAL_SMARTCARD_Receive(&hsc1, response2, 30, 100);
    HAL_UART_Transmit(&huart2, second, 4, 100);
    HAL_UART_Transmit(&huart2,response2,5,100);
    while (1)
    /* USER CODE END 3 */
  • \$\begingroup\$ So what kind of hardware and connections you have between STM32 and the smart card? \$\endgroup\$
    – Justme
    Feb 22 at 14:45
  • \$\begingroup\$ stm32 it direct connection to smart card, PA9(USART1_TX) and PA8(USART_CK) soldered to I/O(7-pin) and CLK(3-pin) from smart card and send/recive hex value via HAL_SMARTCARD_Transmit()/HAL_SMARTCARD_Receive() \$\endgroup\$
    – SAP4K
    Feb 22 at 16:14
  • \$\begingroup\$ So no power supply for the card? No pull-up for open-drain bi-dir comms? Show the schematics, the problem may not even be in the code. \$\endgroup\$
    – Justme
    Feb 22 at 16:39
  • \$\begingroup\$ I edited my question, PB12 and PB13 will be set on high level. after i get ATR from smart card. If you need other details, please ask me. \$\endgroup\$
    – SAP4K
    Feb 22 at 17:30
