Need help identifying the 6 pins SMD IC. This is a push button controller for servos with LEDs to identify position. Appears to say either Z14 or 214.
Close up:
Bottom:
Original image: https://i.sstatic.net/huC9D.jpg
Top:
Original image: https://i.sstatic.net/eVT6c.jpg
    \$\begingroup\$ What are the markings? It looks like "214"? Please review our ID guidelines and edit your question. \$\endgroup\$
    – Null
    Commented Feb 22 at 14:58
    \$\begingroup\$ Maybe the MUN5314DW1? \$\endgroup\$ Commented Feb 22 at 15:05
It is a NC7WZ14P6X from ONSEMI (SOT-363).
Unfortunately i couldn't find any picture with your marking. If you look in internet you'll find old markings because originally it was a Fairchild product. However with that PCN you have the confirmation that the marking matches with the datasheet and your photo.
  • \$\begingroup\$ Thank you for the info. \$\endgroup\$ Commented Feb 22 at 21:40
Chris, That does look like a NC7WZ14P6X. Furthermore, along with the SMD capacitor and push button, it appears that the Z14 is being used as a hardware button debouncer.
