i generated a verilog netlist file with the help of a test case for 2-1 encoder .To test the netlist i draw the schematic diagram and try to find the output.I can't upload the pic of schematic which i draw by hand but below is the verilog file
module test (input [1:0] in, input enable, output reg out);
always @(in or enable)
if(!enable)
out = 4'b0000;
else begin
case (in)
2'b00 : out = 0 ;
2'b01 : out = 1;
2'b10 : out = 0;
2'b11 : out = 1;
endcase
end
endmodule
which says that output must be 0,1,0,1
i generated a netlist which is given below
module test(enable, in, out);
input [1:0] in;
input enable;
output out;
wire synth_net_4;
wire synth_net_9;
wire synth_net_12;
wire synth_net_17;
wire synth_net_19;
wire synth_net;
GND synth_GND_0(.out(synth_net_4));
GND
synth_GND_1(.out(synth_net_12));
MUX4 synth_MUX(.in({synth_net_17,
synth_net_12, synth_net_9, synth_net_4}), .select({in[1], in[0]}), .out(
synth_net_19));
VCC synth_VCC_2(.out(synth_net_9));
VCC synth_VCC_5(.out(
synth_net_17));
BUF synth_BUF(.in(enable), .out(synth_net));
AND2 synth_AND(
.in({synth_net_19, synth_net}), .out(out));
endmodule
but schematic with respect to this netlist give output as 1,0,1,0.So am i doing something wrong in getting exact schematic?I just want to validate that netlist corresponds exactly to verilog file.
out
is only determined by the LSB ofin
. therefore synthesis has optimised the mux and only given you a 1 bit mux. \$\endgroup\$out = in[0] & enable
. \$\endgroup\$
