This is a homework question.
I know that: Given a transfer function of \$H(s)\$ below, we can realize it with an OP-AMP as follows.
\$H(s)=-\dfrac{2}{s+2}=-\dfrac{\dfrac{1}{2}}{\dfrac{s}{4}+\dfrac{1}{2}}=-\dfrac{Z_f}{Zi}=-\dfrac{\dfrac{R_f}{R_f*s*C_f+1}}{Rin}\$
where \$R_{in}=R_f=\dfrac{1}{2}\Omega\$ and \$C_f=1\text{F}\$
However, now that I have to realize a transfer function with complex numbers, I am puzzled on how to do so. Could you lead me to the correct direction on realizing the following transfer function using OP-AMP(s)?
\$H(s)=\dfrac{1}{s + 0.383 + j*0.924}\$
Above equation is a part of:
\$H(s)=\dfrac{1}{s^2 + 0.765*s + 1}=\dfrac{1}{s + 0.383 + j*0.924}*\dfrac{1}{s + 0.383 - j*0.924}\$
Note: In the big picture, I have to realize a HPF of 4th order using cascaded(serial) decomposition method. Normalized transfer function of the filter is given as:
\$H(s)=\dfrac{s^4}{s^4 + 2.613*s^3 + 3.414*s^2 + 2.613*s + 1}\$
This can be written as:
\$H(s)=\dfrac{s^2}{s^2 + 0.765*s + 1}*\dfrac{s^2}{s^2 + 1.848*s + 1}\$
\$=\frac{s}{s + 0.383 + j*0.924}*\frac{s}{s + 0.383 - j*0.924}*\frac{s}{s + 0.924 + i*0.383}*\frac{s}{s + 0.924 - i*0.383}\$
