-1
I need help to connect 10 LED string lights into single plug. I wanted to make sure I have enough power, but not burn out the lights.
this is what i'm planning to do
  • \$\begingroup\$ You needn't add "need help" in your question title. Simply by posting a question we can infer that you require assistance. \$\endgroup\$
    – JYelton
    Feb 27 at 17:38
  • \$\begingroup\$ Sorry, this is my first time using this site. \$\endgroup\$
    – Nick
    Feb 27 at 17:57
  • \$\begingroup\$ Nick, you just need a Buck converter in between the 12V out and the 5V-in. So, instead of "can i", ask "how can i", and you will get better success. Specifically, you can ask, "I want to do this:" and change the above picture to include a rectangle with "Buck Converter" between the 12V-out and the 5V-in, and say, "Please help me either pick a buck converter or make a buck converter that will do this." Then provide a "power budget" saying, "each widget draws a max of 0.25 Watt, so I have to provide a max of 10*0.25W=2.5W." And.... Welcome to Electrical Engineering Stack Exchange! \$\endgroup\$ Feb 27 at 18:53
  • \$\begingroup\$ So ask a "New and improved" question, please! \$\endgroup\$ Feb 27 at 18:54
  • \$\begingroup\$ @MicroservicesOnDDD Presumably, by educating new users. \$\endgroup\$
    – JYelton
    Feb 27 at 18:56
No, you can't connect a 12V supply into devices that are rated for only 5V.
