These two requirements can be made the same i.e. a 3.3 volt regulated supply: -
- MCU: STM32L151, 1.65 V -> 3.6V
- Sensors: 3V - 3.6V
For this requirement: -
- LTE Module: 3.4V -> 4V, Imax < 0.2 A
I would consider using a buck-boost converter set to deliver close to 4 volts (maybe 3.8 volts as you said in a comment to another answer). This will allow the battery voltage to drop below 3 volts or be as high as 4.3 volts (or more).
Then, I'd use a linear regulator to drop down from 3.8 volts to 3.3 volts for the MCU and sensors. I'm presuming here that the MCU and sensors are not current hungry but, if they are maybe an additional buck converter might be necessary (although it's probably unlikely).
