I am in the design phase of building a simple axial flux permanent motor, and I am wondering if I should use a piece of tempered glass as both an insulating material and as part of the motor's frame.
To illustrate the working principle of this conceptual DC electric motor, I have created three conceptual drawings. The first drawing shows two of the primary parts of this motor. The second drawing shows the other two primary parts of this motor. The third drawing shows the assembled primary parts of the motor.
The purpose of using a pot magnet is to minimize the magnet's magnetic field within the interior area of the pot magnet so the rotor and the armature will not be slowed down by it and/or be heated up by it from resistive heating.
I am planning to fasten the circular rails (which will be made using bare 8-gauge solid core copper wires) to the piece of tempered glass using a strong metal-to-glass adhesive. The tempered glass will insulate the electrified circular rails from the pot magnet. Also, the two short pieces of bare wires attached to the armature will also be 8-gauge solid core copper wires.
The two bare copper wires on the armature will slide along on the bare copper circular rails, this direct contact will provide a path for the DC electrical current, and the magnetic interaction between the two rails and the two wires on the armature, along with the magnetic field of the pot magnet, will propel the two wires in a counter-clockwise direction and this will result in rotating the motor's rotor.
An unwanted side effect of this magnetic interaction is that the two rails will repel one another. I am concerned that this repulsion may become strong enough to break the adhesive bond holding the circular rails to the tempered glass if the electric current were to get too high. I think that this could also result in the tempered glass breaking/shattering and this is then a safety issue.
At this point, I do not know what other material that I could use in this motor other than using glass. The benefit of glass is it can take a lot of heat and it is also an electical insulator. This motor will get hot from the friction of wires rotating on wires and also depending on how many amps are run through the wires. I am thinking that this motor can only be run for short periods of time, perhaps for about two minutes or so, and it will then need to be shut off for a short time so the copper wires can cool down.
I am hoping that if someone here on Electrical Engineering.SE agrees that using tempered glass is not a good material to use for this type of motor, that he/she will suggest a different material to use instead of the tempered glass.
Would tempered glass be a good material to use within this simple axial flux permanent magnet motor?
