There is requirement to send transactions (tr) from a uvm_component to a BFM, a uvm_driver. But, there are multiple "imp" ports from component. I am planning to write a task to get transactions from those ports and run them on sequencer like below.
The current idea is to write something similar to the pseudo-code below in the task,
fork
 forever begin
  tr tran;
  tlm_c1.get(tran);
  // add transaction delay
  sequencer_handle.execute_item(tran);
 end
 forever begin
   tr tran;
   tlm_c2.get(tran);
 end
join none
Will it work? Any suggestions would be appreciated.
  • \$\begingroup\$ Please clarify your specific problem or provide additional details to highlight exactly what you need. As it's currently written, it's hard to tell exactly what you're asking. \$\endgroup\$
    – Community Bot
    Commented Mar 11 at 22:15
There are a couple of approaches that come to mind.
  1. UVM TLM FIFO
This class provides storage of transactions between two independently running processes.
  1. UVM Virtual Sequencers
Tests that require coordinated generation of stimulus using multiple driving agents need to use virtual sequences.
