12
Recently, during a discussion with a senior electronics engineer on an industrial project that operates at 48V and is housed within a metallic casing, a point of contention arose regarding ESD compliance. The engineer argued that for ESD compliance, particularly in the rail industry where high-voltage disturbances are a concern, it is a standard practice to connect all unused GPIO pins of the MCU to ground through resistors. This method is believed to mitigate the risk of damage to the MCU from high-voltage perturbations via bounding.
Here is a diagram illustrating the proposed setup:
From my experience, I have never encountered this practice and questioned its necessity, especially in a system operating at a relatively low voltage and with the PCB already grounded through planes on both the top and bottom layers.
Is this grounding solution indeed relevant and necessary for ESD compliance in such a context?
  • 4
    \$\begingroup\$ Connecting unused pins to ground is indeed standard practice in industrial systems. Mainly because of EMI more so than ESD. 1k seems a bit excessive though, 4k7 or 10k are the most common values. As for using pull-down vs tie to ground directly, I can't say I've ever noticed a difference in practice. If you have some horribly old MCU without built-in protection, then it might matter though. PIC isn't exactly bleeding edge technology :) \$\endgroup\$
    – Lundin
    Mar 20 at 11:51
    \$\begingroup\$ They better be set to inputs, not outputs. \$\endgroup\$
    – DKNguyen
    Mar 20 at 14:30
    \$\begingroup\$ I've seen this done for circuit boards in a radiation environment (such as space), all IC pins, including no-connects, must have a resistive path to ground. This prevents charge build up on any pin causing dielectric breakdown. \$\endgroup\$
    – C. Dunn
    Mar 20 at 14:45
  • 5
    \$\begingroup\$ I have never encountered this practice - this concerns me because this is very much standard practice not only in this specific industry but all of electronics design. You only ever leave pins unconnected if you've considered it carefully and know it's OK or if it's documented to be OK to do so. Maybe these days it's not as bad with LED lights but I've personally fried several personal projects in my youth by just turning on the lights (we mostly use fluorescent lighting in my country and the initial blast of high voltage generates significant noise in nearby circuits) \$\endgroup\$
    – slebetman
    Mar 21 at 2:26
  • \$\begingroup\$ @slebetman yes. Pretty basic, actually: reddit.com/r/beneater/comments/ii113p/… \$\endgroup\$ Mar 21 at 5:30
7 Answers 7
22
The PIC24FJ64GA004 Datasheet specifies the general practice for unused I/Os:
2.8 Unused I/Os
Unused I/O pins should be configured as outputs and driven to a logic low state. Alternatively, connect a 1 kΩ to 10 kΩ resistor to VSS on unused pins and drive the output to logic low.
  • 5
    \$\begingroup\$ Using internal pulldowns, or even configuring the MCU to drive the pins to GND should be no less effective than using external resistors. Leaving the pins floating would be bad, but not because of the risk of ESD or high voltage transients. ESD is likely to overpower any pullup/pulldown you put on the pin, so it makes little difference in that regard. Instead, allowing the pins to float between VIL(max) and VIH(min) for extended periods leads to excessive current draw in the pin input buffers (which can damage them). \$\endgroup\$
    – user4574
    Mar 21 at 2:15
    \$\begingroup\$ Additionally toggling IO bits can expose bugs in poorly written code that wasn't expecting them. The result would be mysterious unreproducible software errors attributed to any number of supposed phenomenon. \$\endgroup\$
    – user4574
    Mar 21 at 2:18
    \$\begingroup\$ Just to make this clear: the idea here is to use one resistor per pin, right? Not tie all unused pins together and then share a single resistor? \$\endgroup\$
    – MSalters
    Mar 21 at 14:56
    \$\begingroup\$ @MSalters You are right, the wording is ambiguous. It should be one resistor per unused GPIO pin. \$\endgroup\$
    – Velvet
    Mar 21 at 15:01
    \$\begingroup\$ @user4574 depending on the application and µC the resistor have the advantage that they are always there. The µC pin configuration may differ from the intended in the phase of startup (or possibly in a bootloader phase while updating), or even while sleeping. We have for our product identified situations with voltage transients that cause a reset, thus leaving the pins in an indetermined state for most likely the duration of the transient. We therefore employed safety measures in hardware. \$\endgroup\$
    – PlasmaHH
    Mar 21 at 17:17
17
Apart from the valid reasons given in answers, if you are developing a circuit board, it's always useful to have spare IO brought out to a small but convenient test point just in case you suddenly find that you have overlooked something and need that extra IO.
The fact that there might be a resistor pulling it to GND or Vcc is not a big deal at all. However, what can be a big deal is cutting tracks and making a right mess of things.
Give yourself some future-proofing.
    \$\begingroup\$ My experience says that bringing out those test points is a wise move if you have space to fit them. And if you can't, at least pick component packages with legs (as opposed to QFN or BGA) so a solder tech has something to attach a wire to later on. \$\endgroup\$
    – user4574
    Mar 21 at 2:21
10
It might be relevant, but it depends.
And you already talk about two scenarios, you mention tying unused IO pins to ground (without mentioning any resistors so reader may assume direct connection), and then show another case where unused IO pins are tied to ground via 1k resistors.
In general, floating IO pins may be assumed as bad practice.
But, some MCUs don't even enable them as digital inputs, so the input pins that are floating are irrelevant.
However, some MCUs that always keep them as digital inputs, floating voltages can cause excess current consumption. And it is very bad if your MCU accidentally uses data from floating input for some purpose, as it is random.
The obvious choises are to enable internal pull resistors, up or down.
While most MCUs have at least internal pull-ups, not all MCUs have them, and even if they do, they are only enabled when the software runs. So when the software has not yet turned them on, the pins float.
Another option is to turn the pins as outputs. But that also only works when MCU runs and has initialized the pins.
One option is to simply short all unused pins to ground directly. While good, some programmer may have made an error and the pin is set as high output. Or you must use a factory bootloader that uses multiple different interfaces to outputs even if your program does not need the pins.
Some MCU datasheets do recommend 1k to pins that are exposed to noise, with that being specified as PCB track longer than 50mm.
So depending on your scenario it might make sense to use 1k resistors on all unused pins. But it is also in a metal case and only EMI would come through holes in the case (for connectors and wires) and through the wires connected to the board. In an industrial/automotive setting, you might want to take EMI seriously.
It is generally good practice to tie unused GPIO (CMOS) inputs to ground, and outputs to ground or vcc through some resistor value that would otherwise not cause excessive pin currents beyond rated specifications. In the case he mentioned 1K which seems like a good value to keep GPIO currents < 3.3mA assuming Vcc=3.3V.
    \$\begingroup\$ 1K seems the lower limit, right? Why not 2K, or even 10K? Wouldn't that reduce current and even heat? \$\endgroup\$ Mar 20 at 19:26
  • \$\begingroup\$ Yes indeed, 10K is a better compromise. The software should ensure those pins are set as inputs, or if not possible that the GPIO outputs should be pulled low by default, so the resistance to ground is really just an additional measure (besides resistors are cheap !) \$\endgroup\$
    – citizen
    Mar 21 at 8:45
  • \$\begingroup\$ Re "pins as inputs": The data sheet Velvet linked in his answer recommends configuring unused pins as outputs! \$\endgroup\$ Mar 21 at 8:47
  • \$\begingroup\$ @Peter - Reinstate Monica. Yes for this specific device it might be recommended, howver more generally, it is NOT recommended to configure unused GPIOs as outputs, for the sole reason as to : "Avoid possibly shorting the output configured GPIOs to ground or Vcc or other active lines in the vicinity !". If the recommendation is to have them as merely as outputs, then better it also recommends they be set low at initialisation, otherwise one might just drive them high or whatever - not a very good idea as already mentioned ! \$\endgroup\$
    – citizen
    Mar 21 at 10:35
Look at Microchip's AN1416 app note: https://ww1.microchip.com/downloads/en/Appnotes/90001416a.pdf#page=15 under Hardware Design.
Unused Port Pins
By default, PIC microcontroller I/O pins power up as inputs. A digital input pin consumes the least amount of power when the input voltage is near VDD or VSS. If the input is at some voltage between VDD and VSS, the transistors inside the digital input buffer are biased in the linear region and they will consume a significant amount of current. On an unused I/O pin, which is left floating, the voltage on the pin can drift to VDD/2 or oscillate, causing the unused I/O pin to consume signif- icant power. The I/O pin can use as much as 100 μA if a switching signal is coupled onto the pin.
An unused I/O pin should be left unconnected, but con- figured as an output pin, driving to either state (high or low), or configured as an input with an external resistor (about 10 kΩ) pulling it to VDD or VSS. If such a pin can be configured as an analog input, the digital input buffer is turned off, preventing the excess current consump- tion caused by a floating signal. Any of these methods will prevent the floating node case, minimizing power.
Analog Inputs
Analog inputs have a very high impedance so they con- sume very little current. They will consume less current than a digital input if the applied voltage would normally be centered between VDD and VSS. Sometimes, it is appropriate and possible to configure digital inputs as analog inputs when the digital input must go to a low-power state.
Digital Inputs and Outputs
As long as a digital input is pulled to VDD or VSS, only the pin input leakage current will be consumed.
There is no additional current consumed by a digital output pin, other than the current going through the pin to power the external circuit. Close attention should be paid to the external circuits to ensure that the output is being driven to the state which causes the lowest power consumption. If an external circuit is powered down, make sure that any I/O pin connected to it is driven low to prevent sinking current through the disabled circuit.
For digital inputs and outputs with high switching frequencies, make sure that there is no stray capacitance on the bus by minimizing trace length and eliminating unnecessary components.
Not enough experience to comment too much, other than it sounds like using the analog mode is the best if power is your primary concern and output mode driven low if your primary concern is EMI. This can sometimes be challenging when routing so many pins close to each other especially since they are essentially useless. Looking at the diagram though, it does seem this chip is way overkill if you have that many unused io pins. If this is designed to be modified later, then you probably should route them now to something, although it is not impossible to solder to individual pins that only have pads without tracks.
Setting all the unused gpio as outputs and typing to ground (can use 0 ohm resistors if the design is mature and firmware is stable) also has the benefit of lowering the IC's ground impedance which is always a good thing. It can help with EMC and signal integrity amongst other things.
  • \$\begingroup\$ Exactly. I do the same. No 0ohm resistors. In most cases, you can't really damage an MCU by having GPIO shorted to ground and driving it to a logic 1 state - not if you're using a current-limited supply for the MCU (as one should be!). \$\endgroup\$ Mar 22 at 19:51
I'm late to the party, but I want to provide some additional comments. It's helpful when considering ESD and EMI effects to go back to the basics of circuit analysis or maybe even electromagnetics.
Let's consider the case where your electronics are in an enclosed metal chassis. Suppose there's a large potential voltage between the chassis and some other device. In that case, the potential will equalize when the device or material is close enough to contact the chassis or create a dielectric breakdown (arc). Then the electrons on the surface of one of the devices will flow to the other to evenly distribute the charges. This flow of charges can be measured as a current, and the current will generate a voltage across segments of the chassis that is related to the resistance (or conductance) of the enclosure. Higher currents and/or higher resistance means more power dissipation and more heating.
If for some reason, the resistive path through your electronics is lower or on the same order as your enclosure, the current will flow through your electronics. This can be avoided, however, if you only connect your electronics to the chassis at a single point. This way, fault currents on the chassis cannot flow through the electronics. We call this a single-point grounding scheme (SPG). Using SPG is very common in high-reliability applications such as industrial or aerospace settings for this exact reason. I won't go into this now, but it's important to know that SPG is not the best grounding scheme for all applications.
For your application, if your device is in a conductive enclosure, and has an SPG, your ESD concern should already be pretty low. However, ESD is not the only thing you should be considering when it comes to the safety of your electronics. Industrial environments are notorious for high EMI, including low-frequency fields generated by motors, generators, etc. These low-frequency fields can penetrate your enclosure and interact with your electronics.
If your MCU inputs are floating, any EMI on the pins can adjust the voltage to create spurious signals that could cause unexpected behavior, or even worse, damage. This is a bad idea.
If your MCU inputs are tied directly to ground, these spurious signals cannot change the signal on those pins relative to ground, and your inputs and software functionality are safe. However, if your software/firmware is not yet tested, these inputs could accidentally be configured as outputs and driven to levels that may cause damage if there is no other fault protection. Such faults could also be a concern in environments where single-event upsets are a problem (e.g. a bit flip in the control register for an unused pin set the pin to an output high level). This could be a problem whether you intend to configure these pins as an input or an output driven low.
If your MCU leaves these pins as floating inputs with an internal pull-up or pull-down, EMI is not likely to have any effect on them when the board is powered on and running, but you will want to pay attention to the reset state of these pins. When your device is in reset, the I/O may be configured differently than you've programmed.
The overall safest method for terminating unused I/O then is to tie each pin to a resistor to ground and drive the pin as an output low. This protects against EMI and fault conditions in all cases we've discussed here. If the resistor is large enough, you shouldn't see much power consumption, even during fault conditions. If the resistor is too large, the EMI can still couple to the pin and the charge on the pin may accumulate faster than it flows through the resistor, still causing unwanted behavior.
There's a trade-off here that needs to be made, and you should do your homework to ensure you make the right choice. No solution works best for everything. The resistor pull-down may be the safest, but it's not the lowest power, and it's not the most cost/space efficient. Most other methods are safe enough most of the time. What if you have 100 unused I/O? Should you tie each pin to a resistor to ground? As with almost every question I get related to EMC, the answer is "it depends!"
  • \$\begingroup\$ Just a comment that if there is a resistive path through chassis and board, or any other paths, current takes all paths in proportion to the resistance, not just the lowest path. And for fast events like ESD, the inductance of the paths is important. \$\endgroup\$
    – Justme
    Apr 13 at 7:40
