In order to use a GPIO pin to drive a 180 mA mini water pump, the GPIO pin needs to switch a MOSFET or an Optocoupler because it can't safely do 180 mA.
I want to run 16 low-current pumps from 16 GPIO pins. I'll only be running one pump at a time, because the pumps will be powered by the same Li-ion battery as the GPIO device.
Can I use one of those 4- or 8-channel 3.3 V to 5 V logic level converters as mini relays? They are quite cheap and easy to handle. They are made by Adafruit, SparkFun, and there are even 8 channel ones such as this and this. The only problem is that I'll be using the same voltage for the high and the low side.
Alternatively I can use a dedicated solid state relay boards, but those are very heavy-duty and I prefer something lightweight.
No, a bidirectional logic level converter has no current gain, so it won't serve your purpose. However, you could use a Darlington transistor array, such as the ULN200x series.
  • \$\begingroup\$ Thank you for the recommendation. Can you elaborate a little bit? The ULN2001 has IN, OUT, and GND. Where does the extra current come from if I can't attach VCC? \$\endgroup\$
    – Redsandro
    Mar 23 at 12:24
    \$\begingroup\$ The positive side of each pump connects directly to the power supply. Pin 9 should also be connected to that power supply so that the diodes can protect the transistors. \$\endgroup\$
    – Dave Tweed
    Mar 23 at 15:34
No, you can't use these level shifters to drive a 180mA pump even if you manage them to put in right configuration. The shifters, per descriptions, use BSS138 N-FETs. The FETs have 6 Ohm Rds_on even if driven by 4.5V. As such the transistor will dissipate about 200mW, and the tiny SOT-23 case will likely overheat and burn out.
You will need to use a beefier MOSFETS, or see Dave's recommendation regarding the use of ULN2001 IC, it even has all necessary clamping diodes.
  • \$\begingroup\$ I have tested using 3.3V on a bread board and everything works as expected. The 180 mA pump runs for five minutes and the BSS138 doesn't even get noticeably warm. But here's the real puzzle: Once I attach the logic VIN to GPIO in stead 3.3V, it doesn't work anymore. My oscillator shows it turns on for 10 milliseconds and then off again. I can tell the pin is working properly because I can replace the BSS138 with a LED + resistor and then it works. I don't understand what causes the problem, but clearly this won't work. Albeit for different reasons than expected. \$\endgroup\$
    – Redsandro
    Mar 26 at 14:24
