I am currently working on a PCB where it has two onboard voltage regulators. the first one makes V1in=20 V to V1out= 5.5 V. The second voltage regulator makes V2in=5.5 V to V2out=3.3 V.
The 3.3 V voltage regulator used is 171033801 from Würth Elektronik. The output from the 5.5 V voltage regulator is stable regardless of the load on the 3.3 V voltage regulator.
The observations:
- When no load is connected, the voltage regulator produces a stable 3.3 V output as observed in the first oscilloscope image.
- When the CPU is connected to the PCB, the 3.3 V output becomes really noisy as seen in the second image.
- There is a previous iteration of the board where another voltage regulator was used. The above issue doesn't present itself there.
- The data sheet stated that it can provide up to 3 A output signal. When connecting the voltage regulator output to an electronic load, while increasing the load slowly, we could get only 0.7 A output load current until the voltage regulator shut off.
- When switching the electronic load ON-OFF-ON, the load generates peaks in the current. The voltage regulator can only supply 0.5 A without turning off.
- We tried giving up to 34 V as input voltage so as to see if we can get the total 3 A current. We could only measure 1 A at the output.
It's difficult to tell in this image, but on the top are the input capacitors, three of them (47 µF, 2 x 4.7 µF), followed by a 1 µF cap, and the voltage divider resistor that sets the output voltage. To the right is the 5.6 kΩ resistor which sets the switching frequency and to the bottom is the 47 µF output capacitor. I am also adding the 3D model to make it a little easier to understand.
I have also tested the PCB with three more voltage regulators since then, two from eval boards from Würth Electronic (178021501), this has Vin = 10 V but produces 3.3 V) and the 178023801. This has the same voltage regulator type but produces 2 A instead of the 3 A that is on the board.
I have also tried using the L5973D on a separate PCB, and in all three cases I have connected the output to the output cap of the voltage regulator (voltage regulator removed) and they work with no noise on either of the voltage lines(5.5 V and 3.3 V) and the CPU starts up.
I have some new voltage regulator, the same kind that is present on the PCB, I will replace these regulators and see if that helps.
I am beginning to think this maybe a faulty regulator, but that just seems like a easy explanation and im not satisfied with it. The reason for this is because I have 30 PCBs which produce different results when hooked up to a power supply. Some do not produce any output i.e., output is 0 V, some produce a sawtooth-like waveform at about 600-900 mV, and the others produces the above type of noise when the CPU is connected.
This makes no sense since if this was a routing issue, it should not work with the other voltage regulators. I would need a second opinion before I write this off as a faulty regulator.
Edit: I havent come around to doing the testss with regards to what @Deam Franks mentioned, but it seems close to what i think might be happening. I spoke to a person from Würth Elektronik, and he said that there might be some paraitic impedance or transient effect due to the ground planes on the input caps being a seperated and connected only through a via. He also inclined towards maybe a input filtering problem. This makes sense but it doesnt really explain why it works upto 0.5A - 0.7A and stops working after. When i connect a USB to supply the PCB, it introduces alot of noise on the output 3v3 and the input 5v voltage rails. Sometimes I also get 0.85V which is approximately the same as when no feedback from the volatge divider. He said there might be also be a problem by having cold solder points, or something might have gone wrong in the manufacturing process but cannot be sure. He will come next week and give it a once over.
Edit:
The field Application Engineer from Würth Electronik had come around and checked the PCB and ran a few tests. He said that the voltage regulator needs a clean ground plane for the return path. Here in my design i have a trace cutting through this plane at the input capacitors and this is the cause of the volate regulator not working. The Regulators keeps switching between soft restart phase. We did a few tests by adding a cap across the voltage regulator and connecting the grounds together externally with small wires. This seemed to improve the working of the voltage regulator, as we could get about 0.5A more output current as when without. In all the board would need a redesign and better grounding at the voltage regulator and this should fix the issue.
