I have an LNA and a strong interferer hitting it. Knowing the in band input IP3 and input P1 dB of the LNA, that strong interferer would saturate the amplifier if it were in band.
However the interferer happens to be in the roll off region of the LNA, so the LNA gain is reduced in that region. If I consider the roll off to be acting like a filter and if I assume that in the roll off region the input IP3 and input P1 dB remain unchanged, then the interferer would not saturate the LNA.
Now can I assume that the roll off of the LNA gain will really act like a filter? and is my assumption that the input IP3 and input P1 dB remain the same in the roll off region (like in band) a reasonable assumption?
