This might be a simple question but I'm kind of new to resistor networks so for me it's not so straightforward:
I have a digital electronics project. As part of the project I have 8 pins of an IC connected to 8 LEDs. Each LED has its own 100 ohm resistor (it sits between the IC and LED itself).
In order to simplify the PCB design I'd like to use a single 100 ohm resistor network for those LEDs instead of each LED having its own resistor.
Is it possible? How should I connect the replacement exactly?
This is a simplified part of the schema involved (I drew only 2 LEDs and resistors for simplicity). The LEDs are typical 3 mm Kingbright. All 8 LEDs might be on at the same time but for very short period, less than a second.
