Do I start by multiplying 18/s+3 * 1/s+3 = 18/(s+3)^(2)?
Then is it (18/(s+3)^(2))/(1+(18/(s+3)^(2)*4)) = 18 / ((s + 3)^2 * (72 / (s + 3)^2 + 1))?
The most left part in the 2nd line is still correct - however, the most right part is wrong. After multiplying both - numerator and denominator - with (s+3)² the whole expression reduces to
18/[(s+3)² + 72].
But note that this expression is the transfer function of the small inner loop only.
ratsimp(solve(Eq(((vin-vout)*50-4*vout)*18/(s+3)*1/(s+3),vout),vout)[0]/vin)
Commented
Apr 8 at 14:49
18/(s+3)^(2)
becomes \$\dfrac{18}{(s+3)^2}\$ by using this:\$\dfrac{18}{(s+3)^2}\$
<-- you ought to show your steps too because of the poor/difficult format of your final formula and, the lack of steps make it tricky to follow what you did. \$\endgroup\$
