BMS is not battery charger.
Laptop AC-DC 19V 3.42A supply is not a battery charger.
Molicell INR-21700-P42B specification says:
- Max Voltage: 4.2V ± 0.05V
- Protected: No, Unprotected
- Max Continuous Rated Discharge: 45A
This is a serious high-discharge and unprotected Li-Ion cell, and you need to be pretty careful with your battery. You should charge your pack with 16.8 ± 0.2V CHARGER, meaning that the source is set to CC mode (charge current should be limited to 4.2A ) and max output in CV mode must be limited to 16.8V. Overcharging the cells to 4.75V (19/4) will definitely damage them and likely result in fast outgassing with spectacular flames.
