Completely new to electric circuits, what is the simplest and beginner-friendly way to solve for V using source transformation?
I know that the 12 A current source could be transformed into voltage source, so:
12 * 8 = 96 V voltage source takes the place of the former 12 A current source, and the 8 Ω resistor is now in-series with the circuit.
I'm confused on how to solve for 7 A current source using source transformation method, what would the circuit even look like?
  • \$\begingroup\$ Sorry if this looks like a dumb question, I may be overthinking it \$\endgroup\$
    – anawss
    Apr 16 at 8:07
It's the reverse process of what you did earlier. This time you determine the open circuit voltage of the 7 amp source and 14 Ω resistor (98 volts) and, put that 98 volts in series with 14 Ω: -
Start with the 7 amp source and 14 Ω transformation and you end up with two resistors in series (14 Ω and 6 Ω). Then convert back to a current source in parallel with 20 Ω (4.9 amps): -
Now, you should be able to see that both current sources are in parallel and can be combined into one source of 16.9 amps. Can you take it from here?
  • \$\begingroup\$ Hi, so continuing your explanation, I decide to not combine the current sources and transform both into voltage sources, leaving me with a circuit that's in-series (2 voltage sources Vs1 = 96 V, and Vs2 = 98 V. After doing mesh analysis I found the value of i = 0.071 A. and V = 0.071 * 8 = 0.568 V. Is this correct? \$\endgroup\$
    – anawss
    Apr 16 at 11:00
    \$\begingroup\$ No that doesn't sound right. Far too small for the voltage. You should not transform the 8 ohm resistor if you are trying to find the voltage across it. The transformed voltage is not equivalent. \$\endgroup\$
    Apr 16 at 11:14
  • \$\begingroup\$ I'm sorry but I haven't been taught about combining parallel current sources, could you help on elaborating more on how to solve this? \$\endgroup\$
    – anawss
    Apr 16 at 11:21
    \$\begingroup\$ I'd say so @anawss. \$\endgroup\$
    Apr 16 at 13:42
    \$\begingroup\$ Thank you for your patience, Mr. Andy. Wish you all the best in life. \$\endgroup\$
    – anawss
    Apr 16 at 15:13
The wanted voltage is between nodes A and Ground. The writer of the problem has intentionally drawn the wanted voltage like it somehow was a private property of a single resistor to confuse those who do not always remember that voltage is between 2 nodes.
What to do if it must be solved by using source transformations?
Let nodes A and Ground and the 6 ohm resistor stay where they are. Convert the current sources and their parallel resistors to voltage sources which have series resistors. Then you'll have a single loop circuit. Calculate the loop current with Ohm's Law. Calculate the voltage between A and Ground with Kirchhoff's voltage law.
(no ready to copy homework answers, sorry!)
  • \$\begingroup\$ Hi, can you elaborate on how can i convert the 7 A current sources and its parallel resistors to series?, I'm confused since it's inverted (the current source is inside while the resistor is outside the circuit), I don't really understand what do you mean by let nodes A and Ground and 6 ohm stay where they are, not a native speaker here sorry. \$\endgroup\$
    – anawss
    Apr 16 at 8:40
    \$\begingroup\$ This image shows a current source and its equivalent voltage source i.sstatic.net/pBxQsskf.png These 2 circuits do the same, no matter what's connected to X and Y. The end. \$\endgroup\$ Apr 16 at 9:05
  • \$\begingroup\$ Thank you for the explanation, really appreciate it. \$\endgroup\$
    – anawss
    Apr 16 at 15:14
