I was going through this article for learning about ADC error analysis.
In Example 1: Applying TUE and Monitoring a Power Supply you can see the below thing:
May I know from where that loss equation (log2(4.13) = 2.05) came? I mean it's derivation.
2.05 bits of accuracy: that ADC in the example is 12-bit. Does 2.05 bits accuracy mean ENOB is 9.95 bits?
  • \$\begingroup\$ \$log_2(x) = \dfrac{log_{10}(x)}{log_{10}(2)}\$ \$\endgroup\$
    Apr 16 at 10:04
  • \$\begingroup\$ from where that loss equation came \$\endgroup\$
    – Confused
    Apr 16 at 10:07
    \$\begingroup\$ Did you ask this question on a TI site 7 years ago: e2e.ti.com/support/data-converters-group/data-converters/f/… <-- I believe the answer is in there i.e. loss of resolution (an alternative way of describing effective resolution \$\endgroup\$
    Apr 16 at 10:22
  • \$\begingroup\$ That question was asked by me only,7 years ago ,I forgot it. Thanks for finding it out. But this is different I believe. \$\endgroup\$
    – Confused
    Apr 16 at 10:29
    \$\begingroup\$ No, it's related. The effective resolution and the ideal resolution can be subtracted to find the loss of resolution. I'm not trying to be cryptic; I have tried a little to find the proper derivation but ran out of time. \$\endgroup\$
    Apr 16 at 10:33
May I know from where that loss equation(log2(4.13) = 2.05) came
Lets try this approach. If I asked what \$log_2(256)\$ is, the answer you would get is 8.
  • 256 is equivalent to the number of LSbs that you get from an ideal 8 bit ADC.
  • In other words \$2^8 = 256\$ is just like when using regular logs: \$10^3 = 1,000\$
In your question it uses \$log_2(x)\$ to find the equivalent of the error (or loss) in bits. It starts with LSbs and converts them to equivalent ADC bits.
So, in that example of a 12 bit ADC that you linked, the loss of bits is seen as 2.05 making the effective resolution of the ADC drop from 12 to 9.95.
  • You have a 2.05 loss of bits and not a 2.05 bits accuracy
  • No, it's not ENOB; that's a bit different
  • ENOB requires an analysis of the ADC output when the input is a sinewave
Maybe this document (Understanding Noise, ENOB, and Effective Resolution in Analog-to-Digital Converters) might help.
