I am working with a MCP23S17 SPI I/O expander chip in a VHDL project on my Basys 2.
At first glance I thought this was just a simple SPI interface where I put the chip select low and it will give me the data on the MISO line but it looks like it is bit more complicated with commands and initialization needed.
I added some setup bits ("0100" & "000" & "1") that pop out on the MOSI line once when you try to read data. but nothing has changed. There seems to be a lot of registers to hold settings but I have no clue on how to set these.
SPI Control Byte Format
Here is a diagram of how I have it all hooked up. The testing I/O is only to make sure I have some known bits that should show up if the transaction succeeds. I will be using the B side of the chip so if something special needs to happen to read that then please explain. Chip Setup
What needs to happen to read data from the chip?
Here is the SPI module (SPI.vhd) that I have written so far.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity SPI is
    Generic (
        dataWidthN : positive := 8
    port(
        sck: in std_logic; -- clock
        mosi: out std_logic; -- data going into slave
        miso: in std_logic; -- data coming out of slave
        cs: in std_logic; -- chip select
        address: in std_logic_vector(2 downto 0); -- 0 - 7
        data: out std_logic_vector(dataWidthN-1 downto 0);
        debug: out std_logic_vector(1 downto 0)
end SPI;
architecture Behavioral of SPI is
    signal data_reg : STD_LOGIC_VECTOR (dataWidthN-1 downto 0);
begin
    data <= data_reg;
    process (sck)
        variable isSetup: std_logic := '0';
        variable setupBits: std_logic_vector(7 downto 0) := "0100" & address & "1";
        variable setupBitCount: natural := 0;
    begin
        if rising_edge(sck) then  -- rising edge of SCK
            if (cs = '0') then -- SPI CS must be selected
                if (isSetup = '0' and setupBitCount < 7) then
                    mosi <= setupBits(7-setupBitCount);
                    setupBitCount := setupBitCount + 1;
                else
                    isSetup := '1';
                    setupBitCount := 0;
                end if;
                if isSetup = '1' then
                    debug <= "11";
                    -- shift serial data into dat_reg on each rising edge
                    -- of SCK, MSB first
                    data_reg <= data_reg(dataWidthN-2 downto 0) & miso;
                else
                    debug <= "10";
                end if;
            end if;
        end if;
    end process;
end Behavioral;
I have not found many articles talking about this chip using code. I found some Arduino stuff but they all use the SPI library which doesn't help explain what exactly is happening. Here are the few links that I have found:
Edit:
Alright after working on what Dave Tweed said to do. I am able to send and produce the commands on MOSI but nothing comes back on the MISO line. Keep in mind that the FPGA should get the data and I have a logic analyzer that will show the bits if something comes out and my FPGA code is wrong.
CS:   1111000000000000000000000000
MOSI: xxxx0100aaa10000110000000000
MISO: xxxxxxxxxxxxxxxxxxxxxxxxxxxx
Here is the simulation in ISim. **This will not return data on MISO because it is just a simulation with no chip to actually send back proper data.* ISim results
And from a logic analyzer in the real world: Logic Analyzer Results
Here is the update SPI.vhd module code:
library IEEE;
entity SPI is
    Generic (
        dataWidthN : integer := 8
    port(
end SPI;
    type state_type is (idle, s_readSetup, s_read);
begin
    data <= data_reg;
    spi_read: process (sck)
        variable transactionComplete: std_logic := '0';
        variable setupBits: std_logic_vector(15 downto 0);
        variable setupCmdBitCount: natural := 0;  -- setup command is 16 in length
        variable readCmdBitCount: natural := 0;  -- A command is same as dataWidthN
        variable currState: state_type := idle;
    begin
        setupBits := "0100" & address & "1" & "00001100";
        if falling_edge(sck) then  -- rising edge of SCK
            case currState is
            when s_readSetup =>
                    debug <= "10";
                    mosi <= setupBits(setupBits'length-1-setupCmdBitCount);
                    setupCmdBitCount := setupCmdBitCount + 1;
                    -- Move to the next state
                    if setupCmdBitCount >= setupBits'length then
                        setupCmdBitCount := 0;
                        currState := s_read;
                    end if;
                else
                    currState := idle;
                end if;
            when s_read =>
                    debug <= "11";
                    readCmdBitCount := readCmdBitCount + 1;
                    if readCmdBitCount >= data'length then
                        readCmdBitCount := 0;
                        transactionComplete := '1';
                        currState := idle;
                    end if;
                else
                    currState := idle;
                end if;
            -- Idle state: if the state is unknown then we just go idle
            when others =>
                debug <= "00";
                mosi <= '0';
                if cs = '0' and transactionComplete = '0'  then
                    currState := s_readSetup;
                elsif cs = '1' and transactionComplete = '1' then
                    transactionComplete := '0';
                end if;
            end case;
        end if;
    end process;
end Behavioral;
The MCP23S17 is really meant to be connected to a microcontroller. I have used it successfully in a Blackfin-based project. It has a number of internal registers, just like the GPIO ports on a typical microcontroller. Each 8-bit port has a direction register, an input register and an output register, plus registers for input polarity and interrupt-on-change. There's also a global configuration register.
It does default to all-inputs at power up, so if that's all you need, then you just need to create a state machine that reads the two input registers. Note that you need to supply both a chip address byte and then a register address byte for each read cycle.
Also, you need to be aware that this chip has the funky feature of having two different address maps for the registers, depending on the setting of the "BANK" bit. Study this part carefully; it's pretty confusing.
The BANK bit is zero on power-up, so the two registers you want, GPIOA and GPIOB are found at addresses 12 and 13, respectively. Therefore, to read them both, you need to do two 24-clock SPI cycles:
CS:   1111000000000000000000000000111111110000000000000000000000001111
MOSI: xxxx0100aaa10000110000000000xxxxxxxx0100aaa10000110100000000xxxx
MISO: xxxx0000000000000000AAAAAAAAxxxxxxxx0000000000000000BBBBBBBBxxxx
  • "aaa" represents the chip address.
  • "AAAAAAAA" represents the data from port A
  • "BBBBBBBB" represents the data from port B
Note that everything is MSB-first.
  • \$\begingroup\$ Could you give me an example of trying to read A and B sides (what I should pump down MOSI)? Do I need to make this command everytime I want the data? \$\endgroup\$
    – MLM
    May 30, 2013 at 2:01
  • \$\begingroup\$ I have updated my code so that can pipe out those commands correctly (works in simulation and and real world - logic analyzer). You can see my results in the op. Although I am sending these commands on MOSI nothing comes back on MISO. \$\endgroup\$
    – MLM
    Jun 2, 2013 at 0:14
  • \$\begingroup\$ You're using chip address aaa=000. Are you sure the corresponding pins (A2, A1, A0) on the 23S17 are grounded? Also, you seem to have the MOSI data changing on the rising edge of the clock. You should be changing the data on the falling edge, since the 23S17 setup and hold times are relative to the rising edge. \$\endgroup\$
    – Dave Tweed
    Jun 2, 2013 at 0:47
  • \$\begingroup\$ Yep, all A pins are grounded. No change when changing to falling edge: i.imgur.com/ua54TsF.png \$\endgroup\$
    – MLM
    Jun 2, 2013 at 2:27
Have you simulated your VHDL to verify that it is doing what you expect it to?
Your FPGA should be acting as the SPI master but it does not generate the SPI CLK signal. The VHDL process is also clocked from the same SPI CLK signal (sck) and because there is no clock on this signal your process doesn't do anything.
  • \$\begingroup\$ The clock is generated on the top level module and then fed into the SPI module as well as the spi_sck line going to the chip. The simulation looks okay. SW0 goes low and the setup bits pop out. i.imgur.com/irxxmrg.png \$\endgroup\$
    – MLM
    May 30, 2013 at 1:50
  • \$\begingroup\$ That sim picture doesn't prove that your SPI master on the FPGA is working. In fact it doesn't even show it shifting out 8 bits correctly, after 4 bits mosi goes 'U'. To my eyes your VHDL looks logically incorrect. I think you need a more comprehensive test bench to prove that your SPI master is working. \$\endgroup\$
    – Amoch
    May 30, 2013 at 2:33
  • \$\begingroup\$ I see, it seems to shift out the first 4 correct and the debug shows it is setup after 8 clocks but there does indeed seem to be missing 4 bits. You can see the setupBits in the code above: variable setupBits: std_logic_vector(7 downto 0) := "0100" & address & "1"; \$\endgroup\$
    – MLM
    May 30, 2013 at 2:46
  • \$\begingroup\$ Additional note, there is an errata for this part that you may want to pay attention to, IIRC it impacts the address you need to use. \$\endgroup\$
    – Dan Mills
    Nov 29, 2017 at 17:50
