I'm using a TPA6132 headphone amplifier connected to a stereo (TRS) output socket. In my application, the output will usually be used as a line output, and only occasionally with headphones. The audio is actually mono, so typically a TS jack will be plugged in when used as a line output, shorting the ring contact to ground.
The TPA6132 has short circuit protection, but draws over 100 mA in this case, which I would like to avoid, seeing as it would be in this mode most of the time. I've tried a MAX97220, which looks a bit better in this regard, but still draws around 25 mA.
There are chips like the TS3A226 that do ground detection and can disconnect the ring contact, but the ones I could find are made for 4 pin or 5 pin TRRS/TRRRS headset jacks.
Is there any good way to achieve the same kind of ground sensing and disconnection using discrete components, or is there any chip that does what I'm looking for?
I'm also open to alternative suggestions. I've thought about adding series resistors in the low double digit ohm range, but that's similarly wasteful.
