I would like to use this buffer suggested by a user named MOSFET from a previous post I made (Why is buffer output signal reduced to half?).
Image source: Answer to "Why is buffer output signal reduced to half?" by MOSFET posted on Electrical Engineering Stack Exchange and licensed under CC BY-SA 4.0.
I will try to be as detailed as I can here since I have not in the previous posts. I want to design a buffer for a Hartley oscillator which I plan to make operate at 500 MHz. I want the output of the swing oscillator to be 1V peak to peak. Then I want to pass this through a buffer where the output should stay 1V peak to peak. This buffer is for isolation to prevent the 50 ohm measurement instrument from loading the oscillator.
For the sake of providing details, let us say I want the power supply to be 2.5V. The current through the transistors 1mA. This means the DC power should be 2.5mW. Will this buffer work if use appropriate transistor with high fT (8 GHz for example)?
Here is the schematic on LT SPICE. I am not getting sensible results.
