I do have 2 proximity sensors (level sensors) with 3 wire design. They offer to be PNP or NPN and I need to implement them into an RS-232. They are supplied by 24 VDC. Is there somewhat like a commercial converter which can do this?
The parts will be build in as liquid level sensors and the communication within all the system is RS-232 based. I just want to get "a signal" from that channel if the sensor switches from on to off or vice versa. The signal should be continuous.
