I have a brushless sensored DC ESC. The Manufucturer doesn't have instructions. I probably know the purpose of every wire. The three thick wires are for the motor phases, the three wires together (white, red,black) are for the PWM. Right? But I don't understand, why there is an input for a 6-pin-cable. Could someone pls tell me, because the only option is that it is for the hall effect sensors of the motor, but then it would be 3 not 6?
2\$\begingroup\$ Without wires it would be wireless. \$\endgroup\$– TQQQCommented May 12 at 15:38
\$\begingroup\$ You mean it wouldn't be sensored without the 6-pin-cable? or what \$\endgroup\$– user334991Commented May 12 at 15:47
\$\begingroup\$ Please clarify your specific problem or provide additional details to highlight exactly what you need. As it's currently written, it's hard to tell exactly what you're asking. \$\endgroup\$– Community BotCommented May 12 at 16:32
1 Answer
Without manufacturer instructions it is not obvious how the hall effect sensors are expected to be connected. On a search for possible connection topologies found:
Designing the 3-Phase Brushless DC Motor shows a 3 phase BLDC motor with three two pin hall sensors which then requires 6 pins:
How to Connect Brushless DC Motors to an Electronic Controller shows a different possible topology which uses 5 pins, 3 hall effect outputs, voltage supply and ground:
\$\begingroup\$ EY. But did I understand it right, that my motor isn'T compatible with the ESC then? \$\endgroup\$ Commented May 12 at 17:16
