I want to use supercaps in a system for minimal power interruption backup (1-2 seconds). My systems works at - 40 to 85°C.
I have seen that supercaps are usually rated for 1000 - 2000 hours at max temp (say 85°C) and max voltage (say 5.5V).
And from my understanding this rating is the point where the capacitor will loose 30% of its capacitance and its resistance will double.
Now say my system works at average of 45°C (but will peak to 85°C during hottest days for few hours) and instead of using 5.5V I run it from 3V and instead of needing the whole capacitance I am OK with even 50%
How do I calculate the actual lifespan? I don't see charts in the datasheet but only the number of 1000 hrs @85°C with 5.5V.
Generally the estimate that manufacturers recommend is that life doubles for every 10°C below rated. This is the Arrhenius equation with some assumptions.
Some also have a correction factor for slight voltage derating of Vop/Vrated for up to 2x. The factor used is Vop/Vrated.
So at 45°C the life would be 2^4 times the 85°C rating approximately, or 16x the 85°C rating, so 16,000-32,000 hours ignoring any improvement from voltage derating.
n.b. The relevant temperature is the core temperature of the capacitor, not the ambient. There can be a significant difference between the two for power supply capacitors where self-heating is significant. Probably not so much for a supercapacitor in a typical application.
The excursions above 45°C and the time below 45°C will affect the life, so there will be a shelf life (sometimes specified separately).
If you have a known temperature-time curve you could probably write an equation for instantaneous 'wear out' as a function of time and integrate to get an estimate of the life (when wear out passes 1.0, say) for your arbitrary time-temperature curve.
Or, in a simplified form, consider the time spent at 85° as a = 10% and the rest spent at 45°C. We can then write:
Life \$\approx \frac{1}{\frac{a}{2000}+\frac{1-a}{16000}}\approx\$ 9400 hours
  • \$\begingroup\$ What happens after the stated life? It drops by 30% capacitance and resistance doubles. When does it happen again? If I also take more capacitance and very low esr than needed can I also use that? \$\endgroup\$
    – Uriel Katz
    Commented May 14 at 4:24
  • \$\begingroup\$ The wear-out mechanism AFAIUI is that the electrolyte dries out, so ESR increases and capacitance decreases. Since ESR also increase at low temperatures, a worst case would be very low temperatures near end-of-life. Of course if you have more capacitance/lower ESR than your circuit needs to operate your circuit will have longer life since the end-of-life (due to wear-out) point is arbitrary. The opposite is also true. \$\endgroup\$ Commented May 14 at 5:29
Check the application notes. For example, KEMET provides this paper:
Choosing the Right Supercapacitor for your Application
Wurth's ANP012 | How does a Supercapacitor age? Lifetime Model of Electric Double Layer Capacitors also gives curves for temperature, though not a calculation method.
The materials used should be fairly common between manufacturers, but to be sure, check with your manufacturer.
