(Uber-edit - it has come to my attention that I am an ignoramus. This post is being left in place not to highlight my stupidity in particular, but to serve as a warning for others who think transformers are just about winding some wires around each other right? See the separate chat discussion with @periblepsis that explored the depth of my ignorance and taught me stuff!)
I am planning to build a transformer to isolate the device under test for my oscilloscope, so I don't accidentally destroy it. But it occurred to me that it might also help with mains hum in audio processing. Do you think I will see any benefits there?
(edit - also want to point out I'm not planning to use this as an everyday appliance. Only when I specifically want to test something, or maybe do some audio work (if it helps with mains hum). So yes I know it's not super safe, and I'll need to keep an eye on it. But do you think it will work at all? I am probably gonna try it anyway, so what are your predictions?)
The other question I wanted to ask was about my design, because I have a couple concerns. (editing list after reasonable concerns have been raised)
I'm basically gonna use (edit) 6 things (all of which I already have at home)
- A box
- Standard outlets
- A piece of I-beam
- A big spool of high-gauge plastic coated copper wire
- A temperature sensor with display
- 2 Fans for cross ventilation
Here's my design. This is very much a bushcraft kind of design and I understand that, and if you tell me this is a really bad idea I won't do it, but I think it will probably work.
I have a piece of I-beam from a construction job that's cut to the size of a large transformer. I'm going to use that as the core of the transformer, and double-wrap this spool of wire in a 1-1 input/output configuration to give me an isolation transformer from mains.
The box will be fitted with two fans, intake and outtake, to circulate air. In addition I will nuke the project entirely if I test the wire under load and find that it gets too hot.
I know that I will not get very good efficiency using self-wrapped plastic coated wire. I'm OK with losses. My main concerns are temperature and efficiency. I'll of course test it out and make sure it doesn't overheat. But will the losses be so big that I should just not even try it?
If/when I do it I will update this post with some measured results. I'm interested in feedback and success/failure predictions. Thanks in advance for any positive or even negative feedback!
