can I connect the IGBTs in parallel?
Yes, but you have to take certain precautions.
You have two problems:
- Current sharing among all four (4) IGBTs is not perfect, particularly at the instant of turn-on. If one IGBT turns on before the others then it carries the full 150A. The failure of one IGBT may trigger the others to fail.
- The IGBTs are stressed beyond their Safe-Operating-Area (SOA).
Solution for Problem 1:
Give each IGBT its own collector resistor.
An 8Ω resistor per IGBT will give similar discharge time to what you have now with the 2Ω resistor. This will ensure better current sharing, which is independent of variations in Vgs(th) and gate-drive characteristics for all points in time. This limits the maximum drain current to just 41A per IGBT at the instant of turn-on, regardless of what the other IGBTs are doing.
In addition, ensure each IGBT has its own resistor in series with its gate. This also ensures better current sharing at the instant of turn-on, which is the worst-case in your application.
Here is a suggested schematic, note that the schematic editor did not have the IGBT symbol so I used the MOSFET symbol instead.
Solution for Problem 2:
Make sure the gate drive is sufficiently fast that the SOA limit is not breached. Refer to Fig 11 of the datasheet, copied here below; this shows that provided the fall-time of the collector-emitter voltage is below 10us then each IGBT will easily handle the 330V and 41A that will occur at the moment of turn-on.
Link to datasheet:
https://www.onsemi.com/pdf/datasheet/fgh60n60smd-d.pdf
A Vce fall-time of 10us is quite easy to achieve provided the gate driver is capable of supplying the high current to charge the IGBT input capacitance. The datasheet states input capacitance is about 3nF; to change 3nF by 10V in 10us requires a current of:
i = C dv/dt = 3nF x 10V / 10us = 3mA.
However, that is a very tiny gate drive current compared to what is usually found for an IGBT of this size, and does not consider the Miller effect; I would suggest selecting a gate driver that is capable of supplying at least 100 times this per IGBT, so 0.3A per IGBT. Note also that the datasheet presents all the switching data with a gate resistance of 3Ω, which means an instantaneous gate current of over 3A.
Don't Forget About the Humble Resistors
The resistors in this application will be subjected to enormous power for a brief instant of time. 330V on 8Ω ==> 13.6kW!
Of course, this is not continuous, but you must select a good-quality resistor with high pulse power ratings; otherwise it will explode and possibly catch fire.
