In his paper on TSPC logic, professor Razavi talks about use of the following topology as a master slave flip flop
However, I don't know where to give input to this circuit while trying to simulate it in SPICE. I tried using the .ic
command to set the input voltage to the left most PMOS to either VDD
or 0
since he refers to this node as input node in the paper.
we precede it with a third TSPC stage using a clocked PMOS tran- sistor [Figure 6(c)] and tie the output to the input
where Figure 6(c) is the figure I have added above.
When I simulate it using SPICE with the voltage at X initially set to 0, I get the following results and it doesn't seem like a frequency divider or am I making some mistake here? Is this a sizing issue? since he didn't mention any sizes for these topolgies in the paper (I haven't take a Digital IC Design course yet, so I don't know how to properly size the transistors, so any help regarding the same would also be appreciated)
This is my netlist (I am using GF 180nm Open Source PDK):
** sch_path: /foss/designs/ThreeStageMasterSlaveFF.sch
**.subckt ThreeStageMasterSlaveFF
XM1 net1 A GND GND nfet_03v3 L=0.28u W=0.22u nf=1 ad='int((nf+1)/2) * W/nf * 0.18u' as='int((nf+2)/2) * W/nf * 0.18u' pd='2*int((nf+1)/2) * (W/nf + 0.18u)'
+ ps='2*int((nf+2)/2) * (W/nf + 0.18u)' nrd='0.18u / W' nrs='0.18u / W' sa=0 sb=0 sd=0 m=1
XM2 X CK net1 net1 nfet_03v3 L=0.28u W=0.22u nf=1 ad='int((nf+1)/2) * W/nf * 0.18u' as='int((nf+2)/2) * W/nf * 0.18u' pd='2*int((nf+1)/2) * (W/nf + 0.18u)'
XM3 X A VDD VDD pfet_03v3 L=0.28u W=0.22u nf=1 ad='int((nf+1)/2) * W/nf * 0.18u' as='int((nf+2)/2) * W/nf * 0.18u' pd='2*int((nf+1)/2) * (W/nf + 0.18u)'
XM4 net2 CK GND GND nfet_03v3 L=0.28u W=0.22u nf=1 ad='int((nf+1)/2) * W/nf * 0.18u' as='int((nf+2)/2) * W/nf * 0.18u' pd='2*int((nf+1)/2) * (W/nf + 0.18u)'
XM5 A B net2 net2 nfet_03v3 L=0.28u W=0.22u nf=1 ad='int((nf+1)/2) * W/nf * 0.18u' as='int((nf+2)/2) * W/nf * 0.18u' pd='2*int((nf+1)/2) * (W/nf + 0.18u)'
XM6 A CK VDD VDD pfet_03v3 L=0.28u W=0.22u nf=1 ad='int((nf+1)/2) * W/nf * 0.18u' as='int((nf+2)/2) * W/nf * 0.18u' pd='2*int((nf+1)/2) * (W/nf + 0.18u)'
XM7 net3 X VDD VDD pfet_03v3 L=0.28u W=0.22u nf=1 ad='int((nf+1)/2) * W/nf * 0.18u' as='int((nf+2)/2) * W/nf * 0.18u' pd='2*int((nf+1)/2) * (W/nf + 0.18u)'
XM8 B CK net3 net3 pfet_03v3 L=0.28u W=0.22u nf=1 ad='int((nf+1)/2) * W/nf * 0.18u' as='int((nf+2)/2) * W/nf * 0.18u' pd='2*int((nf+1)/2) * (W/nf + 0.18u)'
XM9 B X GND GND nfet_03v3 L=0.28u W=0.22u nf=1 ad='int((nf+1)/2) * W/nf * 0.18u' as='int((nf+2)/2) * W/nf * 0.18u' pd='2*int((nf+1)/2) * (W/nf + 0.18u)'
Vclk CK GND PULSE(0 3.3 0 0 0 0.25ms 0.5ms)
Vsupply VDD GND 3.3
**** begin user architecture code
.include /foss/pdks/gf180mcuC/libs.tech/ngspice/design.ngspice
.lib /foss/pdks/gf180mcuC/libs.tech/ngspice/sm141064.ngspice typical
.ic V(x)=0
.control
save all
tran 1ns 1ms
remzerovec
write ThreeStageMasterSlaveFF.raw
.endc
**** end user architecture code
**.ends
.GLOBAL GND
.GLOBAL VDD
.end
